<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ypvs with AC wiring]]></title><description><![CDATA[<p dir="auto">My dt has AC wiring, mainly because it has HPI electrics. I was wondering is it possible to use the ypv system with ac wiring? If so how? I have regulator for lights and such but since the voltage output changes with the rpms i dont know if it would ruin the servo or not. Or should i add a small battery where servo gets its power? Really dont know and also i sont have an ingition key system since it has AC wiring.</p>
]]></description><link>https://dt125r.co.uk/topic/3554/ypvs-with-ac-wiring</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 12:38:34 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3554.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2026 19:26:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ypvs with AC wiring on Sat, 23 May 2026 06:28:27 GMT]]></title><description><![CDATA[<p dir="auto">..and you need the battery too, not just the regulator. Forgot to write that</p>
]]></description><link>https://dt125r.co.uk/post/33354</link><guid isPermaLink="true">https://dt125r.co.uk/post/33354</guid><dc:creator><![CDATA[Rallyfinnen]]></dc:creator><pubDate>Sat, 23 May 2026 06:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to Ypvs with AC wiring on Sat, 23 May 2026 06:27:10 GMT]]></title><description><![CDATA[<p dir="auto">You need 12V DC for the servo. You could probably use a simple regulator/rectifier from a scooter that has a pin for battery charging. I use this type on a DT LC converted to 12V.</p>
<p dir="auto">Something like this:<br />
<a href="https://www.amazon.se/Universal-Motorcycle-Motorbike-motorcycle-rectification/dp/B09LMJP68D?source=ps-sl-shoppingads-lpcontext&amp;ref_=fplfs&amp;psc=1&amp;smid=A2A8L8R3J2QTTW" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.se/Universal-Motorcycle-Motorbike-motorcycle-rectification/dp/B09LMJP68D?source=ps-sl-shoppingads-lpcontext&amp;ref_=fplfs&amp;psc=1&amp;smid=A2A8L8R3J2QTTW</a></p>
]]></description><link>https://dt125r.co.uk/post/33353</link><guid isPermaLink="true">https://dt125r.co.uk/post/33353</guid><dc:creator><![CDATA[Rallyfinnen]]></dc:creator><pubDate>Sat, 23 May 2026 06:27:10 GMT</pubDate></item></channel></rss>
