<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mystery 35mm inlet]]></title><description><![CDATA[<p dir="auto">My engine is running a dellortto phbh 28mm carb<br />
External diameter of carb is 35mm<br />
The inlet is split near boost bottle<br />
I ve tries two of other inlets but the internal diameter of the standard inlet is only 32mm<br />
So my question is what bike is the 35 mm inlet off its the same angle as standard dtr but slightly larger</p>
]]></description><link>https://dt125r.co.uk/topic/3555/mystery-35mm-inlet</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 01:32:48 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3555.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2026 21:36:51 GMT</pubDate><ttl>60</ttl></channel></rss>
