<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Which pilot jet for Athena 170 and snorkel delete DT125RE]]></title><description><![CDATA[<p dir="auto">Put a 22.5 pilot in and it’s running super lean like it’s got an air leak I sprayed carb cleaner around the manifold, carb and boot can’t say I noticed a leak, cleaned the carb (brass tubes, air vents, jets) previous owner had it running with a zip tie on the choke plunger when it was stock ages ago since I put the 170 in and new jets I took the zip tie off and runs super lean again, turned the air screw all the way in no difference, only runs well with choke partially open</p>
]]></description><link>https://dt125r.co.uk/topic/3562/which-pilot-jet-for-athena-170-and-snorkel-delete-dt125re</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 12:43:17 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3562.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Jun 2026 09:06:55 GMT</pubDate><ttl>60</ttl></channel></rss>
