<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Head gasket]]></title><description><![CDATA[<p dir="auto">Hello<br />
So i have a problem my cylinder head is slightly scratched and a little bent so the regular metal gasket doesnt seal it (coolant gets in the bore) but i found a solution a athena composite head gasket that nicely squished the head together but it was time for a rebuild and i had to tear it down tried to fit a normal headgasket but that didnt hold (found out the hard way) so im in need of the thicker athena composite headgasket but i cant find it anywhere and i cant remember what store i bought it from.</p>
<p dir="auto">Thanks for any help!</p>
]]></description><link>https://dt125r.co.uk/topic/3574/head-gasket</link><generator>RSS for Node</generator><lastBuildDate>Thu, 09 Jul 2026 23:40:09 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3574.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Jul 2026 19:58:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Head gasket on Thu, 09 Jul 2026 20:59:58 GMT]]></title><description><![CDATA[<p dir="auto">Several options</p>
<p dir="auto">Can you not skim the head and barrel and remove the imperfections, then space the barrel with two bottom gaskets?</p>
<p dir="auto">Can you not get yourself a reusable copper head gaaket. They used to be all the range a few years ago.</p>
<p dir="auto">You could always contact an engineering firm like PJME to machine an o-ring into your setup to bypass the imperfections.</p>
<p dir="auto"><a href="https://www.pjme.co.uk/acatalog/Yamaha-DT125R-Head-Gasket-O-Ring--5866.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.pjme.co.uk/acatalog/Yamaha-DT125R-Head-Gasket-O-Ring--5866.html</a></p>
]]></description><link>https://dt125r.co.uk/post/33455</link><guid isPermaLink="true">https://dt125r.co.uk/post/33455</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 09 Jul 2026 20:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to Head gasket on Thu, 09 Jul 2026 20:00:32 GMT]]></title><description><![CDATA[<p dir="auto">forgot to add the part where i ask for help if anyone knows where to get one <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=9222312b850" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://dt125r.co.uk/post/33453</link><guid isPermaLink="true">https://dt125r.co.uk/post/33453</guid><dc:creator><![CDATA[Pilot_LC]]></dc:creator><pubDate>Thu, 09 Jul 2026 20:00:32 GMT</pubDate></item></channel></rss>
