<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dt125x Electric start issue]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’ve got a fault where if I hit the electric start sometime it won’t crank.</p>
<p dir="auto">Battery is good , you can hear the click when you press the button but Nothing.</p>
<p dir="auto">If I put it in gear and roll it a bit it then hit the button it cranks and starts ?</p>
<p dir="auto">The starter motor had been replaced so would this mean it’s the clutch starter that needs replacing ?</p>
<p dir="auto">Appreciate any advice anyone can share.</p>
<p dir="auto">Thanks<br />
Mike</p>
]]></description><link>https://dt125r.co.uk/topic/3588/dt125x-electric-start-issue</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Jul 2026 22:07:37 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3588.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jul 2026 19:31:22 GMT</pubDate><ttl>60</ttl></channel></rss>
