<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Engine missfires over 6000 RPM.]]></title><description><![CDATA[<p dir="auto">Hey guys, so i got my 2006 DT125X about a month ago. It has ran perfectly except a couple of fouled plugs (2-3).<br />
But yesterday it started missfiring around 6000RPM and i cant get over it. The bike starts jerking but it doesnt feel like a carb issue. I thought it was just another fouled plug so i changed that out to a NGK BR9ES. I also cleaned the carb for good measures but no luck. I can also hear the powervalve priming when turning the ignition on.</p>
<p dir="auto">What could it be?</p>
]]></description><link>https://dt125r.co.uk/topic/3589/engine-missfires-over-6000-rpm.</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Jul 2026 19:49:35 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3589.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jul 2026 16:27:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Engine missfires over 6000 RPM. on Thu, 30 Jul 2026 19:30:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Not leaking any fluids. No more smoke than the regular twostroke. Also a knew airfilter is fitted.</p>
]]></description><link>https://dt125r.co.uk/post/33524</link><guid isPermaLink="true">https://dt125r.co.uk/post/33524</guid><dc:creator><![CDATA[HannesDTX]]></dc:creator><pubDate>Thu, 30 Jul 2026 19:30:54 GMT</pubDate></item><item><title><![CDATA[Reply to Engine missfires over 6000 RPM. on Thu, 30 Jul 2026 19:07:27 GMT]]></title><description><![CDATA[<p dir="auto">I mean it could literally be anything.</p>
<p dir="auto">You shouldn't be fouling plugs, ever...</p>
<p dir="auto">So something isn't right there</p>
<p dir="auto">Is it smoking excessively?</p>
<p dir="auto">Are you losing coolant?</p>
<p dir="auto">Are you losing gearbox oil?</p>
<p dir="auto">I've had something similar when I fitted a cheap chinese knock off 'racing' coil, so make sure you have a genuine <code>3RM</code> coil fitted.</p>
<p dir="auto">Make sure the exhaust is cleaned through.</p>
<p dir="auto">Make sure the airbox and inlet tract is cleared through.</p>
<p dir="auto">Measure the HT lead resistance make sure it's within spec.</p>
]]></description><link>https://dt125r.co.uk/post/33523</link><guid isPermaLink="true">https://dt125r.co.uk/post/33523</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 30 Jul 2026 19:07:27 GMT</pubDate></item></channel></rss>
