<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ypvs gears missing]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2463/so-close">So Close!...</a><br />
Hello, I have a problem with my Yamaha dt 125 r 1997. Someone ripped out all of the teeth gears in the ypvs system. I can t find the transmission on the gears. i Found that the smaller gear on the motor itself has 12 teeth and is about 12 mm. but i can t find the dimensions of the other one, any help would be great, thanks!</p>
]]></description><link>https://dt125r.co.uk/topic/3596/ypvs-gears-missing</link><generator>RSS for Node</generator><lastBuildDate>Mon, 24 Aug 2026 16:26:19 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3596.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Aug 2026 13:35:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ypvs gears missing on Mon, 24 Aug 2026 13:49:49 GMT]]></title><description><![CDATA[<p dir="auto">Oh how annoying! I've seen this before when people have incorrectly set up the YPVS servo and stripped the teeth on the gears.</p>
<p dir="auto">It's probably easier to just buy another YPVS servo sadly than trying to find the individual cog.<br />
<a href="https://www.ebay.co.uk/itm/307114030022?_skw=Yamaha+DT+125+R+YPVS+servo&amp;itmmeta=01M0T0CTAKVKYBVERW4KK9HKJQ&amp;hash=item47816c33c6:g:QqIAAeSwkVdqdvO2&amp;itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xDV5F88zNLFmQlOj5cc4%2FxlPVfMrS0CX9zdgmCMx0exrIiMBYEnl2C70gEhZcvwr3BYq%2BewLJHyMjxf%2BATBLTUnAq5B4Os%2FAuVyeOUNpVSRYxblUNuwL%2BjqWn0F95mbpkEWkXEDU%2F4blrRDuajNXDPVd8py1aTbWsSecsyFqwFQqqWjrgMG65s52PTjh2LPZ%2FOmWbQsy4dMVcVkq6VX2lCX6cdUUBN6SMPZHm3xNkDwYsJXuOa1TCyyOEaSwcuLKfJrQwb9YP1PtVMNdQS0UqCxAXfBI4hQNMZjPJwu4V6qdKAjffzCnESPO3DSoS0%2FsfE%3D%7Ctkp%3ABk9SR9als8CGaA" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ebay.co.uk/itm/307114030022?_skw=Yamaha+DT+125+R+YPVS+servo&amp;itmmeta=01M0T0CTAKVKYBVERW4KK9HKJQ&amp;hash=item47816c33c6:g:QqIAAeSwkVdqdvO2&amp;itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xDV5F88zNLFmQlOj5cc4%2FxlPVfMrS0CX9zdgmCMx0exrIiMBYEnl2C70gEhZcvwr3BYq%2BewLJHyMjxf%2BATBLTUnAq5B4Os%2FAuVyeOUNpVSRYxblUNuwL%2BjqWn0F95mbpkEWkXEDU%2F4blrRDuajNXDPVd8py1aTbWsSecsyFqwFQqqWjrgMG65s52PTjh2LPZ%2FOmWbQsy4dMVcVkq6VX2lCX6cdUUBN6SMPZHm3xNkDwYsJXuOa1TCyyOEaSwcuLKfJrQwb9YP1PtVMNdQS0UqCxAXfBI4hQNMZjPJwu4V6qdKAjffzCnESPO3DSoS0%2FsfE%3D|tkp%3ABk9SR9als8CGaA</a></p>
<p dir="auto">If you have access to the a 3D printer, or are capable on CAD, you <em>might</em> be able to 3D print a new set of teeth, setting the TPU to 100% fill should be strong enough to cope with the demand. My 3D printer is pretty darn accurate so it would probably do a fair go at it to be fair.</p>
]]></description><link>https://dt125r.co.uk/post/33572</link><guid isPermaLink="true">https://dt125r.co.uk/post/33572</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 24 Aug 2026 13:49:49 GMT</pubDate></item></channel></rss>
