<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PTFE bushings and bearings]]></title><description><![CDATA[<p dir="auto">Hey everyone! I just got done rebuilding the rear end of my DTR. I changed the rear shock lower bearing, the linkage bushings and collars and seals. For the shock bearing and the linkage bushings I decided to go with PTFE lined bushings instead of oem. I read that these don't require any grease at all, so I ended up running them dry but my gut is telling me that's not right. My question is wether you think I should've greased them and will running them dry shorten their lifespan.<br />
Thank you</p>
]]></description><link>https://dt125r.co.uk/topic/3623/ptfe-bushings-and-bearings</link><generator>RSS for Node</generator><lastBuildDate>Wed, 28 Oct 2026 12:10:21 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3623.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Oct 2026 09:33:20 GMT</pubDate><ttl>60</ttl></channel></rss>
