<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What is this piece on intake?]]></title><description><![CDATA[<p dir="auto">Can someone explain me what is that piece in the picture, because on my bike there is just shiny bit sticking out. Just wondering because I can't get my bike to idle. <img src="/uploads/files/1479489516367-upload-71db10e8-3b7f-4adb-8d66-ea1e0d3059c1.png" alt="0_1479489513913_upload-71db10e8-3b7f-4adb-8d66-ea1e0d3059c1" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/topic/461/what-is-this-piece-on-intake</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 10:59:25 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/461.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Nov 2016 17:18:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 21:19:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hobo4life" aria-label="Profile: HOBO4LIFE">@<bdi>HOBO4LIFE</bdi></a> Yep looks like a great price too</p>
]]></description><link>https://dt125r.co.uk/post/3745</link><guid isPermaLink="true">https://dt125r.co.uk/post/3745</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 18 Nov 2016 21:19:10 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 20:15:53 GMT]]></title><description><![CDATA[<p dir="auto">Will that one fit? ebay link</p>
]]></description><link>https://dt125r.co.uk/post/3744</link><guid isPermaLink="true">https://dt125r.co.uk/post/3744</guid><dc:creator><![CDATA[HOBO4LIFE]]></dc:creator><pubDate>Fri, 18 Nov 2016 20:15:53 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 20:06:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hobo4life" aria-label="Profile: HOBO4LIFE">@<bdi>HOBO4LIFE</bdi></a> Well then that sounds like your problem. The carb may not be setup correctly. There is an idle screw on the side that can be adjusted to correct the idle.</p>
<p dir="auto">The YEIS is there for a reason.</p>
]]></description><link>https://dt125r.co.uk/post/3743</link><guid isPermaLink="true">https://dt125r.co.uk/post/3743</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 18 Nov 2016 20:06:00 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 19:18:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> This started to happen after carburettor was cleaned, by professional mechanic. Also I never had it.</p>
]]></description><link>https://dt125r.co.uk/post/3739</link><guid isPermaLink="true">https://dt125r.co.uk/post/3739</guid><dc:creator><![CDATA[HOBO4LIFE]]></dc:creator><pubDate>Fri, 18 Nov 2016 19:18:41 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 19:01:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hobo4life" aria-label="Profile: HOBO4LIFE">@<bdi>HOBO4LIFE</bdi></a> Oui Oui Oui.</p>
<p dir="auto">Get the bike back to stock to try and sort it out.</p>
]]></description><link>https://dt125r.co.uk/post/3738</link><guid isPermaLink="true">https://dt125r.co.uk/post/3738</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 18 Nov 2016 19:01:49 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 19:00:23 GMT]]></title><description><![CDATA[<p dir="auto">So does it add more hp? Will this fit my dtx? <a href="http://www.ebay.co.uk/itm/DT125-DTR-YEIS-Chamber-/122226147114?hash=item1c753eff2a:g:1VgAAOSwh-1W4Dwb" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ebay.co.uk/itm/DT125-DTR-YEIS-Chamber-/122226147114?hash=item1c753eff2a:g:1VgAAOSwh-1W4Dwb</a></p>
]]></description><link>https://dt125r.co.uk/post/3737</link><guid isPermaLink="true">https://dt125r.co.uk/post/3737</guid><dc:creator><![CDATA[HOBO4LIFE]]></dc:creator><pubDate>Fri, 18 Nov 2016 19:00:23 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 18:36:12 GMT]]></title><description><![CDATA[<p dir="auto">YEIS. Yamaha Engine Intake System. It uses the engines harmonic resonance frequency at a recession in the engines combustion phase to draw in a needed supply of oxygen. If it has been removed then you will not benefit from the performance gains. But it needs to be properly blanked off else it will cause a vacuum leak and won't idle</p>
]]></description><link>https://dt125r.co.uk/post/3736</link><guid isPermaLink="true">https://dt125r.co.uk/post/3736</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 18 Nov 2016 18:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to What is this piece on intake? on Fri, 18 Nov 2016 23:53:25 GMT]]></title><description><![CDATA[<p dir="auto">Doubt it'll be anything to do with your idling. <a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> knows the rough science behind it but it's supposed to be beneficial for the engine in some way.</p>
]]></description><link>https://dt125r.co.uk/post/3735</link><guid isPermaLink="true">https://dt125r.co.uk/post/3735</guid><dc:creator><![CDATA[Mightyman]]></dc:creator><pubDate>Fri, 18 Nov 2016 23:53:25 GMT</pubDate></item></channel></rss>
