<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Water pump]]></title><description><![CDATA[<p dir="auto">I got a water pump repair kit it's got an extra bit in not sure where or even if it goes in the 1 I took out didn't have 1 <img src="https://i.imgur.com/kekyrrI.jpg" alt="0_1486139642741_20170203_163032.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/topic/548/water-pump</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 19:10:04 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/548.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Feb 2017 16:34:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Water pump on Sat, 04 Feb 2017 15:00:42 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure and i can't see it in the service manual</p>
]]></description><link>https://dt125r.co.uk/post/4356</link><guid isPermaLink="true">https://dt125r.co.uk/post/4356</guid><dc:creator><![CDATA[Ricky]]></dc:creator><pubDate>Sat, 04 Feb 2017 15:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to Water pump on Fri, 03 Feb 2017 17:57:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a> but isn't there two different sizes of water pump impeller seal?</p>
]]></description><link>https://dt125r.co.uk/post/4353</link><guid isPermaLink="true">https://dt125r.co.uk/post/4353</guid><dc:creator><![CDATA[Mightyman]]></dc:creator><pubDate>Fri, 03 Feb 2017 17:57:10 GMT</pubDate></item><item><title><![CDATA[Reply to Water pump on Fri, 03 Feb 2017 17:36:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mightyman" aria-label="Profile: Mightyman">@<bdi>Mightyman</bdi></a> All DTRs use the same Water-pump,</p>
]]></description><link>https://dt125r.co.uk/post/4352</link><guid isPermaLink="true">https://dt125r.co.uk/post/4352</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Fri, 03 Feb 2017 17:36:37 GMT</pubDate></item><item><title><![CDATA[Reply to Water pump on Fri, 03 Feb 2017 17:56:22 GMT]]></title><description><![CDATA[<p dir="auto">Not 100% sure.. But it might be that the supplier just throws in both the seals from the newer model clutch case, as well as the older model. The difference is shown in these pictures.<br />
<img src="https://i.imgur.com/SMo1LIA.jpg" alt="0_1486140688166_s-l1600.jpg" class=" img-fluid img-markdown" /><br />
<img src="https://i.imgur.com/2lLUg1B.jpg" alt="0_1486140730975_s-l1600 (1).jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/post/4351</link><guid isPermaLink="true">https://dt125r.co.uk/post/4351</guid><dc:creator><![CDATA[Mightyman]]></dc:creator><pubDate>Fri, 03 Feb 2017 17:56:22 GMT</pubDate></item></channel></rss>
