<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[rear brake slider bolt&#x2F;pin]]></title><description><![CDATA[<p dir="auto">finally had a day off on friday so started on fitting the new brakes rear caliper was seized solid after two hours of dash and heating and finally putting it in a vice and tighting it up with a bar got it to move slightly and then got it free buggered up the slider boot seal and ordered a new one but cant find the slider bolt/pin has a allen head to tighten it up does anybody know where or if you can buy new ones looked all over and cant see it listed on parts drawings</p>
]]></description><link>https://dt125r.co.uk/topic/597/rear-brake-slider-bolt-pin</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 00:27:53 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/597.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Mar 2017 21:02:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to rear brake slider bolt&#x2F;pin on Mon, 06 Mar 2017 21:52:07 GMT]]></title><description><![CDATA[<p dir="auto">@CYBER-NINJA cheers mate</p>
]]></description><link>https://dt125r.co.uk/post/4805</link><guid isPermaLink="true">https://dt125r.co.uk/post/4805</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Mon, 06 Mar 2017 21:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to rear brake slider bolt&#x2F;pin on Mon, 06 Mar 2017 19:58:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/britshgigolo" aria-label="Profile: britshgigolo">@<bdi>britshgigolo</bdi></a> Try this dude, he breaks DT's, so he may have one;</p>
<p dir="auto"><a href="https://www.facebook.com/tommy.keane.98" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.facebook.com/tommy.keane.98</a></p>
]]></description><link>https://dt125r.co.uk/post/4804</link><guid isPermaLink="true">https://dt125r.co.uk/post/4804</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Mon, 06 Mar 2017 19:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to rear brake slider bolt&#x2F;pin on Sun, 05 Mar 2017 20:09:02 GMT]]></title><description><![CDATA[<p dir="auto">@CYBER-NINJA !<img src="https://i.imgur.com/GyVD0xY.jpg" alt="0_1488744533417_s-l1600.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/post/4790</link><guid isPermaLink="true">https://dt125r.co.uk/post/4790</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Sun, 05 Mar 2017 20:09:02 GMT</pubDate></item><item><title><![CDATA[Reply to rear brake slider bolt&#x2F;pin on Sun, 05 Mar 2017 19:44:16 GMT]]></title><description><![CDATA[<p dir="auto">will get pic up next week when i fit the new rubber boot as all back together no its the one that the caliper slides on you have to lift the caliper up to slide it off the pin/bolt its the one thats fitted to the mounting bracket if that makes any more sence but will get pic as soon as rubber boot turns up</p>
]]></description><link>https://dt125r.co.uk/post/4788</link><guid isPermaLink="true">https://dt125r.co.uk/post/4788</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Sun, 05 Mar 2017 19:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to rear brake slider bolt&#x2F;pin on Sun, 05 Mar 2017 11:24:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/britshgigolo" aria-label="Profile: britshgigolo">@<bdi>britshgigolo</bdi></a> Post a pic dude, as that might be more helpful in recognising the part you require???</p>
]]></description><link>https://dt125r.co.uk/post/4780</link><guid isPermaLink="true">https://dt125r.co.uk/post/4780</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sun, 05 Mar 2017 11:24:33 GMT</pubDate></item></channel></rss>
