<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using kn filter on dt]]></title><description><![CDATA[<p dir="auto">Not sure if this is I. The right section</p>
<p dir="auto">Who on here has used a kn type filter on their dt<br />
Do you need to change jets<br />
I ve read that you have to space the carb out 60mm or you get a flat spot<br />
I can't use the standard air box as the dt engine is in a different bike</p>
]]></description><link>https://dt125r.co.uk/topic/62/using-kn-filter-on-dt</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 20:00:41 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/62.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Sep 2015 06:35:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using kn filter on dt on Tue, 22 Sep 2015 20:01:33 GMT]]></title><description><![CDATA[<p dir="auto">Just copy and paste the link mate.</p>
<p dir="auto">Yeah, my advice would be to have a shield made that would shield it from the majority of exposure. Not uncommon practice for air filters.</p>
<p dir="auto">As said I've never had an issur and I've ridden in all sorts.from sunny to torrential rain. But perhaps your situation may be more difficult.</p>
<p dir="auto">Some photos might be handy here so we xan visualise the problem.</p>
]]></description><link>https://dt125r.co.uk/post/192</link><guid isPermaLink="true">https://dt125r.co.uk/post/192</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 22 Sep 2015 20:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to Using kn filter on dt on Tue, 22 Sep 2015 16:28:29 GMT]]></title><description><![CDATA[<p dir="auto">I can't open the link<br />
I need to run a airbox the engine is a lot lower in the chopper frame  an exposed to water etc</p>
<p dir="auto">I m planning on using a kn filter cutting the air box so it's in two halves an the filter will be encased inside<br />
This has took much thought than fitting the engine</p>
]]></description><link>https://dt125r.co.uk/post/188</link><guid isPermaLink="true">https://dt125r.co.uk/post/188</guid><dc:creator><![CDATA[dan28]]></dc:creator><pubDate>Tue, 22 Sep 2015 16:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to Using kn filter on dt on Sat, 19 Sep 2015 16:40:50 GMT]]></title><description><![CDATA[<p dir="auto"><code>http://pages.ebay.com/link/?nav=item.view&amp;id=390495861787&amp;alt=web</code></p>
<p dir="auto">This is what I run on my dt, just 32mm</p>
]]></description><link>https://dt125r.co.uk/post/178</link><guid isPermaLink="true">https://dt125r.co.uk/post/178</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 19 Sep 2015 16:40:50 GMT</pubDate></item></channel></rss>
