<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Removing spray paint from plastics]]></title><description><![CDATA[<p dir="auto">Just wondering what the easiest method is removing black spray paint without scratching the Blue plastics <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--+1" style="height:1.4em;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
]]></description><link>https://dt125r.co.uk/topic/726/removing-spray-paint-from-plastics</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 03:18:52 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/726.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 May 2017 20:38:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Removing spray paint from plastics on Tue, 02 May 2017 19:29:10 GMT]]></title><description><![CDATA[<p dir="auto">You could try something called Modelstrip.  Available from many model shops, it strips paint off plastic models without damaging the plastic.  Obviously test a small area first.  Brake fluid will whiten the plastic.  Bear in mind they were likely sprayed because they were worn out.</p>
<p dir="auto">As someone else said, it would likely be cheaper and better just to buy new.  I bought a new rear fender for £20 from Fowlers.  Cheap as chips.</p>
]]></description><link>https://dt125r.co.uk/post/6090</link><guid isPermaLink="true">https://dt125r.co.uk/post/6090</guid><dc:creator><![CDATA[Alastair]]></dc:creator><pubDate>Tue, 02 May 2017 19:29:10 GMT</pubDate></item><item><title><![CDATA[Reply to Removing spray paint from plastics on Tue, 02 May 2017 01:00:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rogering" aria-label="Profile: rogering">@<bdi>rogering</bdi></a> Buy new plastics in the required colour is the best way to get the results which you seek. Maybe a bit costlier, but ultimately the best solution. <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--wink" style="height:1.4em;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://dt125r.co.uk/post/6088</link><guid isPermaLink="true">https://dt125r.co.uk/post/6088</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Tue, 02 May 2017 01:00:59 GMT</pubDate></item><item><title><![CDATA[Reply to Removing spray paint from plastics on Mon, 01 May 2017 21:33:37 GMT]]></title><description><![CDATA[<p dir="auto">My dtx had 6 owners and lots of abuse. Was left long time on the sun . The plastics have some type of gloss  coat which peels off with decals . Before Im applied decals Im degreased whole bike for best possible grip and there is still bits that coming off...</p>
<p dir="auto">I think its ok to use thinners to remove the old paint or thinners mixed with paint stripper.</p>
]]></description><link>https://dt125r.co.uk/post/6087</link><guid isPermaLink="true">https://dt125r.co.uk/post/6087</guid><dc:creator><![CDATA[Zrako]]></dc:creator><pubDate>Mon, 01 May 2017 21:33:37 GMT</pubDate></item><item><title><![CDATA[Reply to Removing spray paint from plastics on Mon, 01 May 2017 20:56:27 GMT]]></title><description><![CDATA[<p dir="auto">Soak in brake fluid, but probably damaged underneath, why else would they be painted?</p>
]]></description><link>https://dt125r.co.uk/post/6084</link><guid isPermaLink="true">https://dt125r.co.uk/post/6084</guid><dc:creator><![CDATA[Louis-DT-WR]]></dc:creator><pubDate>Mon, 01 May 2017 20:56:27 GMT</pubDate></item></channel></rss>
