<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutchless Gearshifting]]></title><description><![CDATA[<p dir="auto">To all the lads out there, damage occurs significantly quicker on any gearbox.</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=p09goXGd9Ro" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=p09goXGd9Ro</a></p>
<p dir="auto">My DT gearbox is now rough as arse,</p>
]]></description><link>https://dt125r.co.uk/topic/729/clutchless-gearshifting</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 11:22:35 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/729.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 May 2017 22:45:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutchless Gearshifting on Thu, 04 May 2017 19:26:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> aye , in emergency cases its something different than regular bipassing the clutch</p>
]]></description><link>https://dt125r.co.uk/post/6175</link><guid isPermaLink="true">https://dt125r.co.uk/post/6175</guid><dc:creator><![CDATA[Zrako]]></dc:creator><pubDate>Thu, 04 May 2017 19:26:58 GMT</pubDate></item><item><title><![CDATA[Reply to Clutchless Gearshifting on Thu, 04 May 2017 19:22:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zrako" aria-label="Profile: Zrako">@<bdi>Zrako</bdi></a> When you haven't got a choice, i.e. clutch cable snap, I'm saying it's going to  cause next to zero damage if done right.</p>
]]></description><link>https://dt125r.co.uk/post/6173</link><guid isPermaLink="true">https://dt125r.co.uk/post/6173</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 04 May 2017 19:22:41 GMT</pubDate></item><item><title><![CDATA[Reply to Clutchless Gearshifting on Thu, 04 May 2017 19:18:37 GMT]]></title><description><![CDATA[<p dir="auto">I've been told to shift without the clutch on my bikes and Im tried , said no. Didnt liked it and its habit to pull that lever <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f603.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--smiley" style="height:23px;width:auto;vertical-align:middle" title="😃" alt="😃" /></p>
]]></description><link>https://dt125r.co.uk/post/6171</link><guid isPermaLink="true">https://dt125r.co.uk/post/6171</guid><dc:creator><![CDATA[Zrako]]></dc:creator><pubDate>Thu, 04 May 2017 19:18:37 GMT</pubDate></item><item><title><![CDATA[Reply to Clutchless Gearshifting on Thu, 04 May 2017 18:17:28 GMT]]></title><description><![CDATA[<p dir="auto">I've never had a problem with it personally</p>
]]></description><link>https://dt125r.co.uk/post/6161</link><guid isPermaLink="true">https://dt125r.co.uk/post/6161</guid><dc:creator><![CDATA[andrewj1680]]></dc:creator><pubDate>Thu, 04 May 2017 18:17:28 GMT</pubDate></item><item><title><![CDATA[Reply to Clutchless Gearshifting on Thu, 04 May 2017 11:26:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> True, we all know what a clutch-less shift is.</p>
<p dir="auto">But the point is, a clutch-less shift is dependent on matching the speed of the next gear and no additional torque from the rear wheel into the output shaft.</p>
<p dir="auto">When this happens, the clutch-less shift works the same as just shifting with the clutch.</p>
<p dir="auto">The fact is, the clutch is better for consistently doing this going up the box, thus less wear over time,</p>
]]></description><link>https://dt125r.co.uk/post/6104</link><guid isPermaLink="true">https://dt125r.co.uk/post/6104</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Thu, 04 May 2017 11:26:50 GMT</pubDate></item><item><title><![CDATA[Reply to Clutchless Gearshifting on Wed, 03 May 2017 23:06:36 GMT]]></title><description><![CDATA[<p dir="auto">Hhmm, not really convinced.</p>
<p dir="auto">Since the output shaft is connected to the rear wheel and the rear wheel is actually still spinning at some crazy RPM it almost seems a moot point.</p>
<p dir="auto">Besides you don't keep the power on with a clutchless shift the idea is you shut the throttle off whilst you shift, ergo no torque to damage the gearbox.</p>
<p dir="auto">The same would be said if you used the clutch but kept the throttle wide open. You would damage the gearbox just as much if not more. You wouldn't shift with the clutch in throttle wide open, so why would you shift no clutch throttle wide open...</p>
]]></description><link>https://dt125r.co.uk/post/6101</link><guid isPermaLink="true">https://dt125r.co.uk/post/6101</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 03 May 2017 23:06:36 GMT</pubDate></item></channel></rss>
