<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[oil pump stroke]]></title><description><![CDATA[<p dir="auto">should my oil pump increase the stroke when the throttle plate is lowered? it seems to not really change:<br />
<a href="https://youtu.be/DGJRkeKesxQ" target="_blank" rel="noopener noreferrer nofollow ugc">video</a></p>
]]></description><link>https://dt125r.co.uk/topic/74/oil-pump-stroke</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 03:44:41 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/74.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Oct 2015 20:07:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to oil pump stroke on Thu, 15 Oct 2015 07:48:45 GMT]]></title><description><![CDATA[<p dir="auto">Yes that's what I thought, but the stroke should still increase at any speed if the pulley is depressed? I'm sure I gave it enough time as it went up/down a few times?<br />
I took the pump off the engine, and a load of oil ran out of the pump where worm gear shaft goes into the pump body. Is that normal? There is a gasket there, but is that worm gear cavity supposed to be full of 2T lube?</p>
]]></description><link>https://dt125r.co.uk/post/277</link><guid isPermaLink="true">https://dt125r.co.uk/post/277</guid><dc:creator><![CDATA[rockthecasbah]]></dc:creator><pubDate>Thu, 15 Oct 2015 07:48:45 GMT</pubDate></item><item><title><![CDATA[Reply to oil pump stroke on Tue, 13 Oct 2015 22:12:27 GMT]]></title><description><![CDATA[<p dir="auto">The oil pump runs off the gearbox. The higher the rpms the more it pumps.</p>
<p dir="auto">The height of the pump is determined by the pitch of the throttle. I don't think you gave it enough time to actually depress.</p>
<p dir="auto">If you think its broken then my advice would be to ditch it and run premix. They are liability anyway.</p>
]]></description><link>https://dt125r.co.uk/post/276</link><guid isPermaLink="true">https://dt125r.co.uk/post/276</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 13 Oct 2015 22:12:27 GMT</pubDate></item><item><title><![CDATA[Reply to oil pump stroke on Tue, 13 Oct 2015 20:11:06 GMT]]></title><description><![CDATA[<p dir="auto">comparing to these which look to work fine:<br />
<a href="https://youtu.be/gosF90z39M0" target="_blank" rel="noopener noreferrer nofollow ugc">rd</a></p>
<p dir="auto"><a href="https://youtu.be/gOGSakbuve4" target="_blank" rel="noopener noreferrer nofollow ugc">pump</a></p>
<p dir="auto">anyone got a good oil pump for sale?!</p>
]]></description><link>https://dt125r.co.uk/post/275</link><guid isPermaLink="true">https://dt125r.co.uk/post/275</guid><dc:creator><![CDATA[rockthecasbah]]></dc:creator><pubDate>Tue, 13 Oct 2015 20:11:06 GMT</pubDate></item></channel></rss>
