<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Yamaha DT125R &#x27;01 - Running Project]]></title><description><![CDATA[<p dir="auto">Well. I sometimes wonder why I bother. If you have ever ridden a proper Off-road motorcycle, you quickly realise when thraping a DT, just what a sqeegey, pogo stick, slightly too small, floppy forked, 80s steel timer chassis it really is. When it comes to modifying a DT. You might aswell buy something better. But anyway, I like playing with it so..</p>
<p dir="auto">Fitted a 1/4 Action throttle from a 1988 KX80. The throttle tube is a larger diameter, much more comfortable and has been invaluable as an upgrade. I had to modify my 'Genuine' throttle cable by cutting back a bit of outer sheath. XT600 brake lever is a great swap, and I use a little shorty alloy clutch lever of a 85cc on there.</p>
<p dir="auto"><img src="https://c2.staticflickr.com/6/5729/22350673881_a6969caf24_c.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
Needed to replace the original headlight cluster.</p>
<p dir="auto">Missed out on a decent Yamaha WR400 headlight.(Perfect shape) Got one of a Aprilia RX, had to do some wiring for this. Needed to be painted white of course. Its worse than the DT headlight.. but, got the look.</p>
<p dir="auto"><img src="https://farm1.staticflickr.com/771/22340043755_232c615426_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">If your into DTRs. Then the DT200R (3ET) is the one to have. I couldn't find much information on these (YZ) wheel upgrades I've seen. I wanted alloy wheels on it like the 200. So after some research and a failed attempt at getting a set of WR200 wheels, I concluded that 1988-94 Yamaha YZ wheels have the same size rear hub as the DT. Straight swap. For the front, had to be 1987'-1988' because they ran similar sized rotors back then. However the hubs are about 10mm wider on the YZ, So I chose some YZ 1986' front spacers, looked similar proportion to match a DT fork in the pictures. If your going to swap to a YZ wheel, I gave up trying to fit the Speedo drive back on and took it off. Took of the clocks. Then fitted a bicycle wired speedo, just for an MOT really.. its crap and does not register the pick up past 60 mph or so. Minor price to pay. A vapour unit out of the budget. Don't need idiot lights for wheelies.</p>
<p dir="auto">Yamaha built the 1986-1988 YZs with Gold anodised rims and man.. wish I could find a back one. The front is a 1988- the back of a 1994. MX was starting to use 19" rear wheels for better drive and handling back in the early 90s. Yamaha were on this on the YZ range.  Bigger wheel does throw the gearing off slightly on acceleration. Got a big dutty knobbly on the back and you really loose out on power if you have to nip along the road.</p>
<p dir="auto"><img src="https://farm6.staticflickr.com/5744/22152302588_a9a039c499_z.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The rear shock is crap on any DTR, or at least mine was. Did some googling' and a man in Australia agreed with me, and I had to copy his idea for myself. The DT uses the same shock to linkage fixing as 87-88' YZs  Shipped a 1987' Yamaha YZ490 Rear shocker that bolts right in! Its even got Yamaha's 'B.A.S.S' system on it. Which is rubbish.. but cool anyway. When fitting it, the top damper mount on a YZ frame is different, apparently much narrower than the DT frame, so you will need to use the bearing with it's fixed spacer off the DT shock and replace the YZ one with it. I actually used two big cable ties instead just to stop any lateral movement under compression. Anyway I now have Adjustable spring rate, Damping settings and Rebound settings. It will sit pretty high on a firm setting. 4-5cm lift. I also stuck with my short Dog-bones,3cm riser ones. It gives the shock better clearance from the swing arm, its a tight fit.</p>
<p dir="auto">I cannot find the thread any more, but here are the pictures on the suspension modifications</p>
<p dir="auto"><img src="https://c1.staticflickr.com/6/5657/22313992896_0cda0f1f74_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">I already replaced the battery with a capacitor from '2strokeracelab' - check it out. The shock is bigger than the DT unit, longer and a fatter spring with of course,with a piggyback reservoir. So there is no room for the battery. It is also no going back as there is the tab which the battery tray is bolted to on the frame, which has to be cut off for the shock to be accepted properly. I also cut the side cover apart. Bit easier to get a flat head in for adjustment and gives me access to the Yamy Tool kit.</p>
<p dir="auto"><img src="https://farm1.staticflickr.com/632/22153186239_b8013b363d_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">I use 15w Fork oil and it makes the best of the standard forks. I do own a very nice set of 1991' WR200 Kayaba Forks. I chose them because the WR yoke had an Ignition mount. They are just the right forks for it. But I don't want to modify the frame to accept the WR stem. I'm looking at having the Stem pressed from the WR yoke, and getting it machined down with an extended thread which would allow me to just use the original top cap and ball bearing race on the DT. Need to model it in 3D first.</p>
<p dir="auto">I'm at University currently so I just stock pile things at the moment. But future updates; Installing a Twin radiator configuration from the DT200R(3ET) - Got all the goodies now. I've also got a 'Ignitech DCCDPI2' on the way. The 3RM' really needs ignition modification before anything else. And the fiendishly unfriendly, how do I horse anything bigger than a 30mm Carburettor? plans to Original Air box configuration at some point,</p>
<p dir="auto">It does not need to be big, I have drilled out the Air box already with good results with some Jetting and Pipecross Airfilter fitted. But I do have a Keihin PWK 36 that would be alot of fun.</p>
<p dir="auto"><img src="https://farm6.staticflickr.com/5833/22340040945_4c9445a037_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Picked up a very nice Yamaha TZR125RR (3MB00-P-Y2) Barrel ages ago. (The real deal Y3 Belgarda' has eluded me) Just a display piece at the moment. Interested to hear about any Porting experiences.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://dt125r.co.uk/topic/77/yamaha-dt125r-01-running-project</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 02:41:39 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/77.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2015 20:17:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Sun, 18 Oct 2020 19:46:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/finchfocker" aria-label="Profile: finchfocker">@<bdi>finchfocker</bdi></a> I myself just bought the DCCDIP1 race. Seems like a great unit, just programmed myself a ignition map to start off with, hopefully I'll get a chance to plug her in soon!</p>
]]></description><link>https://dt125r.co.uk/post/25081</link><guid isPermaLink="true">https://dt125r.co.uk/post/25081</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Sun, 18 Oct 2020 19:46:25 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Wed, 14 Oct 2020 05:43:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a> what ignitec cdi did you go for?? Ive sent an email and they have recommended the DCCDIP1 race</p>
]]></description><link>https://dt125r.co.uk/post/25043</link><guid isPermaLink="true">https://dt125r.co.uk/post/25043</guid><dc:creator><![CDATA[finchfocker]]></dc:creator><pubDate>Wed, 14 Oct 2020 05:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Fri, 04 Sep 2020 06:47:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> Alright, I'll get myself a pair of those! Thanks!</p>
]]></description><link>https://dt125r.co.uk/post/24608</link><guid isPermaLink="true">https://dt125r.co.uk/post/24608</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Fri, 04 Sep 2020 06:47:46 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 23:41:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peluri" aria-label="Profile: Peluri">@<bdi>Peluri</bdi></a> the Chinese footpegs look nice been meaning to get a set</p>
]]></description><link>https://dt125r.co.uk/post/24604</link><guid isPermaLink="true">https://dt125r.co.uk/post/24604</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Thu, 03 Sep 2020 23:41:48 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 17:52:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Really nice! My only problem is the budget, those things are like a 100€ <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f62c.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--grimacing" style="height:23px;width:auto;vertical-align:middle" title="😬" alt="😬" /> Maybe I should get some Chinesium ones <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f605.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--sweat_smile" style="height:23px;width:auto;vertical-align:middle" title="😅" alt="😅" /></p>
]]></description><link>https://dt125r.co.uk/post/24602</link><guid isPermaLink="true">https://dt125r.co.uk/post/24602</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Thu, 03 Sep 2020 17:52:24 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 15:02:01 GMT]]></title><description><![CDATA[<p dir="auto">Yeah it was simple. I tried looking I could find exactly what I bought. I must have done it after I "finished" my bike and thus didn't document it. But yeah was a really easy mod and now I have Phat footrests.</p>
]]></description><link>https://dt125r.co.uk/post/24598</link><guid isPermaLink="true">https://dt125r.co.uk/post/24598</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 03 Sep 2020 15:02:01 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 14:54:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Ok so they fit easily? I'll think about getting myself a pair of those then!</p>
]]></description><link>https://dt125r.co.uk/post/24597</link><guid isPermaLink="true">https://dt125r.co.uk/post/24597</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Thu, 03 Sep 2020 14:54:51 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 13:15:58 GMT]]></title><description><![CDATA[<p dir="auto">I just ground down the ends of them as they wouldn't sit flush. It's a very minor mod I didn't think twice about it.</p>
]]></description><link>https://dt125r.co.uk/post/24596</link><guid isPermaLink="true">https://dt125r.co.uk/post/24596</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 03 Sep 2020 13:15:58 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 12:41:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> That's nice, how do the KTM pegs fit the DTR? Any modding needed or bolt-on?</p>
]]></description><link>https://dt125r.co.uk/post/24595</link><guid isPermaLink="true">https://dt125r.co.uk/post/24595</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Thu, 03 Sep 2020 12:41:37 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 08:03:59 GMT]]></title><description><![CDATA[<p dir="auto">I am running Apico KTM ones. Nice and wide.</p>
]]></description><link>https://dt125r.co.uk/post/24594</link><guid isPermaLink="true">https://dt125r.co.uk/post/24594</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 03 Sep 2020 08:03:59 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 03 Sep 2020 07:13:22 GMT]]></title><description><![CDATA[<p dir="auto">You should really get some better foot pegs! I think the  WR200 ones fit right on.</p>
]]></description><link>https://dt125r.co.uk/post/24593</link><guid isPermaLink="true">https://dt125r.co.uk/post/24593</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Thu, 03 Sep 2020 07:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Wed, 02 Sep 2020 09:11:26 GMT]]></title><description><![CDATA[<p dir="auto">Yeah that's looking lovely mate. It's a lovely looking machine.</p>
<p dir="auto">I don't think this is the end for you mate. I reckon you need throw a set of USD forks on there for completeness.</p>
<p dir="auto">That would just be <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44c.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--ok_hand" style="height:23px;width:auto;vertical-align:middle" title=":ok_hand:" alt="👌" /> Perfect then!</p>
]]></description><link>https://dt125r.co.uk/post/24592</link><guid isPermaLink="true">https://dt125r.co.uk/post/24592</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 02 Sep 2020 09:11:26 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Wed, 02 Sep 2020 15:04:08 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Exhaust Porn</strong></p>
<p dir="auto">This was the last one ever left, I finally bit the bullet and purchased a Stainless exhaust for the DT.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50295725596_5d485fee71_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">This came all the way from bloody Portugal like this <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f602.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--joy" style="height:23px;width:auto;vertical-align:middle" title=":joy:" alt="😂" /></p>
<p dir="auto">Great job lads.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50113127797_5bb846d5f4_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50113112327_7ec261860a_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50113114687_ccf61b6182_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50112303433_527ccd2f41_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Ballin' - This is the 'YAMAHA DT125 Special Exhaust' in STAINLESS DTX DTR-E with end can from <strong>Romeu125</strong> an eBay seller.<br />
Custom design by the gang over there and beautifully hand made.</p>
<p dir="auto">Really quite impressed, only ever 4 sold on eBay.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50291951431_9e69973593_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Looks great, low slung -  Interesting design. I've got to say, did not fit that well with the tail pipe supplied. It was so awkward in fact I decided to fit my WR200 FMF tail pipe DIY instead.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50295801351_116af545f6_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Looks cool, but too raspy for my taste.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50296091932_8067a1bbe3_b.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
Picked up maybe the last NOS WR200 Mikuni Idle screw ever? This stuff is all getting expensive and stupidly hard to come by these days...</p>
<p dir="auto"><strong>Airbox</strong><br />
<img src="https://live.staticflickr.com/65535/50291952911_cd1d362c16_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Next up, finishing up the Airbox. Drilled and bolted up with M5 bolts and importantly using Nylocs. Can't have the ingestion of M5 bolts into the crankcase.</p>
<p dir="auto">Got it bang on with a perfect seal, sadly it's no going back with the install but that's the best that can be achieved SLA 3D printing.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50295869307_79c0555d54_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>WR200 SideStand - 1991-1993</strong></p>
<p dir="auto">The early versions of the WR200 came with a long enduro style kickstand. Almost impossible to find nowadays and I'm kicking myself for not getting one NOS from Fowlers back in the day, but I was a student at the time.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50295128833_11ef505ac9_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Due to the design you need to notch the DTR frame, so 'sayonara' fresh powdercoat here and sent it with the Grinder. It looks like I've cut to far there, but it's just swarf.</p>
<p dir="auto">Again, NO GOING BACK.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50295254478_1f8fae0499_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The WR200 sidestand looks mint, tucks up nicely and props the bike up much further if you run an increased ride height over standard on the DTR.</p>
<p dir="auto">(New longer spring needed)</p>
<p dir="auto"><strong>FINAL FORM</strong></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50291806" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">I'm running DT230 Lanza Frame Guards, Left handside here is a ZETA part. Otherside is an OEM Lanza Part which only fits right handside for the DTR and require spacers and machining to fit the DTR. But worth it.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50291980172_0ab8271872_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>HOT BOI</strong></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50291933662_c392f8e2ff_b.jpg%22" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Such an odd Croissant that pipe....,</p>
<p dir="auto">I think that's it for the DTR, It's a beast, sounds great and is still alot of fun 7 years on. But it's had it’s day.</p>
<p dir="auto">Is it better? All I'm certain is that it's mine.<br />
.</p>
]]></description><link>https://dt125r.co.uk/post/24590</link><guid isPermaLink="true">https://dt125r.co.uk/post/24590</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Wed, 02 Sep 2020 15:04:08 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Thu, 27 Aug 2020 05:38:31 GMT]]></title><description><![CDATA[<p dir="auto">Hey darty, could you share us the files for your 3D printed intake manifold and airbox thingy?</p>
]]></description><link>https://dt125r.co.uk/post/24527</link><guid isPermaLink="true">https://dt125r.co.uk/post/24527</guid><dc:creator><![CDATA[Peluri]]></dc:creator><pubDate>Thu, 27 Aug 2020 05:38:31 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Tue, 07 Jul 2020 22:36:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a> tm34ss is the perfect upgrade due the the shape and angle, keeps the float bowl level .<br />
I think there's a tm36ss also</p>
]]></description><link>https://dt125r.co.uk/post/24094</link><guid isPermaLink="true">https://dt125r.co.uk/post/24094</guid><dc:creator><![CDATA[Louis-DT-WR]]></dc:creator><pubDate>Tue, 07 Jul 2020 22:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Tue, 30 Jun 2020 04:49:07 GMT]]></title><description><![CDATA[<p dir="auto">Actually amazing that you can 3D print parts!</p>
<p dir="auto">I need to get myself a 3D printer. Can just imagine the hassle I could save!</p>
]]></description><link>https://dt125r.co.uk/post/23993</link><guid isPermaLink="true">https://dt125r.co.uk/post/23993</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 30 Jun 2020 04:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Mon, 29 Jun 2020 22:38:29 GMT]]></title><description><![CDATA[<p dir="auto">Prototype V4, 3D printed in a TPU at 80A Shore Hardness like the original. This is chemical and UV resistant filament and it's rather tough!</p>
<p dir="auto">This is the final design for use with a pressure mold.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50059794801_69c27d4d0a_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50059794771_ef9067980e_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50059226083_49d0fc85fd_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Concessions need to be made for 3D printing rubber unfortunately, so now I'm using M5 Socket cap bolts and the original flange that's molded in the Airbox as a sealing face, it actually works out to be the most effective alternative. Much like a YZ Airbox will use the same design.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50060039472_129f98b0c9_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50059225838_912e38437c_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50060039422_4f8826f3e0_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The Airbox is so important when jetting a 2stroke road bike, we need to control the flow of air and have a place to store some also! Induction theory carries on. The area inside is free of interruption and the boot helps to increase the velocity upon entering the carb. I'm hoping to gain more torque down low by using that stock Airbox volume.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50060081302_0eacb731ea_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The design now minimises any angles greater than 55deg, this means material does not have to be supported as we print. As you can see, this is the optimal version as the rest of the print can completed cleanly as a vertical slice.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50059809346_1507589d85_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Job done,</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50060053697_7678fdf267_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50060054142_9deccd9f7b_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50060055497_4e45427d3b_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/50059766411_685aa460bc_b.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">So much more flexibility with jetting. Measure 69 times, draw it once.</p>
<p dir="auto">Mikuni TM34ss finally finished.</p>
]]></description><link>https://dt125r.co.uk/post/23990</link><guid isPermaLink="true">https://dt125r.co.uk/post/23990</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Mon, 29 Jun 2020 22:38:29 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Tue, 05 May 2020 21:59:04 GMT]]></title><description><![CDATA[<p dir="auto">I am also working on a custom inlet. Very cool inspiration here</p>
]]></description><link>https://dt125r.co.uk/post/23375</link><guid isPermaLink="true">https://dt125r.co.uk/post/23375</guid><dc:creator><![CDATA[Sven Hackbarth]]></dc:creator><pubDate>Tue, 05 May 2020 21:59:04 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Mon, 27 Apr 2020 11:33:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonne123" aria-label="Profile: jonne123">@<bdi>jonne123</bdi></a> Never got round to it, I’m looking to get it Dyno’d in the future</p>
]]></description><link>https://dt125r.co.uk/post/23255</link><guid isPermaLink="true">https://dt125r.co.uk/post/23255</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Mon, 27 Apr 2020 11:33:19 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Fri, 24 Apr 2020 19:38:58 GMT]]></title><description><![CDATA[<p dir="auto">Darty do you have accelaeation video or something like that or dyno result</p>
]]></description><link>https://dt125r.co.uk/post/23209</link><guid isPermaLink="true">https://dt125r.co.uk/post/23209</guid><dc:creator><![CDATA[jonne123]]></dc:creator><pubDate>Fri, 24 Apr 2020 19:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Tue, 21 Apr 2020 09:25:03 GMT]]></title><description><![CDATA[<p dir="auto">@Rizboy We fitted a 38mm keihin carb to a 2001 DTR</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=bOGAEzTaBgI" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=bOGAEzTaBgI</a></p>
<p dir="auto">Just used a heat gun to up the carb boot and reamed out the inlet manifold to suit.</p>
]]></description><link>https://dt125r.co.uk/post/23135</link><guid isPermaLink="true">https://dt125r.co.uk/post/23135</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 21 Apr 2020 09:25:03 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Tue, 21 Apr 2020 07:59:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a> How do you fit 36mm carb on your dt,what kind of carb boot use for it.</p>
]]></description><link>https://dt125r.co.uk/post/23134</link><guid isPermaLink="true">https://dt125r.co.uk/post/23134</guid><dc:creator><![CDATA[Tuan Rizkhan]]></dc:creator><pubDate>Tue, 21 Apr 2020 07:59:27 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Mon, 20 Apr 2020 20:50:23 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to every possibly carb option for a DTR, the darty edition.<br />
Never heard of Nikkon before. Pretty pipe I must add proper phat boi. Also good to see you cracking on at last man</p>
]]></description><link>https://dt125r.co.uk/post/23129</link><guid isPermaLink="true">https://dt125r.co.uk/post/23129</guid><dc:creator><![CDATA[Stevie Wonder]]></dc:creator><pubDate>Mon, 20 Apr 2020 20:50:23 GMT</pubDate></item><item><title><![CDATA[Reply to Yamaha DT125R &#x27;01 - Running Project on Mon, 20 Apr 2020 16:51:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> said in <a href="/post/23114">SuperDeet125R '01 - Running Project</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: NINJA">@<bdi>NINJA</bdi></a> Sorry, should I have used the "Quote" feature. I was just relaying that <a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a> Said it's taken him 4 years and a pandemic to sort his brakes out.</p>
</blockquote>
<p dir="auto">As the saying goes; "Better late than never!!!" <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /> <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f600.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--grinning" style="height:23px;width:auto;vertical-align:middle" title=":grinning:" alt="😀" /> <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=76a0dbc3e80" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /></p>
]]></description><link>https://dt125r.co.uk/post/23122</link><guid isPermaLink="true">https://dt125r.co.uk/post/23122</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Mon, 20 Apr 2020 16:51:28 GMT</pubDate></item></channel></rss>
