<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[bike dies when put into gear]]></title><description><![CDATA[<p dir="auto">the engine on my dt125r is running fine until i put it in gear and its as if the side stand down but its not so i disconnected it and the same problem still happens. any advice</p>
]]></description><link>https://dt125r.co.uk/topic/771/bike-dies-when-put-into-gear</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 10:57:54 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/771.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 May 2017 17:04:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to bike dies when put into gear on Wed, 17 May 2017 17:57:40 GMT]]></title><description><![CDATA[<p dir="auto">Yeah it's  a <code>normally open</code> circuit and you have to close the circuit for it to work.</p>
]]></description><link>https://dt125r.co.uk/post/6605</link><guid isPermaLink="true">https://dt125r.co.uk/post/6605</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 17 May 2017 17:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to bike dies when put into gear on Wed, 17 May 2017 17:58:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mightyman" aria-label="Profile: Mightyman">@<bdi>Mightyman</bdi></a> True, mine wouldnt even start,</p>
]]></description><link>https://dt125r.co.uk/post/6604</link><guid isPermaLink="true">https://dt125r.co.uk/post/6604</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Wed, 17 May 2017 17:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to bike dies when put into gear on Wed, 17 May 2017 17:48:25 GMT]]></title><description><![CDATA[<p dir="auto">You can't just disconnect the side stand switch, you have to instead finish off the circuit by joining the wires if I'm right? <a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a></p>
]]></description><link>https://dt125r.co.uk/post/6602</link><guid isPermaLink="true">https://dt125r.co.uk/post/6602</guid><dc:creator><![CDATA[Mightyman]]></dc:creator><pubDate>Wed, 17 May 2017 17:48:25 GMT</pubDate></item><item><title><![CDATA[Reply to bike dies when put into gear on Wed, 17 May 2017 17:38:53 GMT]]></title><description><![CDATA[<p dir="auto">Side stand switch mate.</p>
]]></description><link>https://dt125r.co.uk/post/6600</link><guid isPermaLink="true">https://dt125r.co.uk/post/6600</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 17 May 2017 17:38:53 GMT</pubDate></item><item><title><![CDATA[Reply to bike dies when put into gear on Wed, 17 May 2017 17:20:37 GMT]]></title><description><![CDATA[<p dir="auto">its electrical it stops sparking when put into gear</p>
]]></description><link>https://dt125r.co.uk/post/6599</link><guid isPermaLink="true">https://dt125r.co.uk/post/6599</guid><dc:creator><![CDATA[jimmydc98]]></dc:creator><pubDate>Wed, 17 May 2017 17:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to bike dies when put into gear on Wed, 17 May 2017 17:13:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jimmydc98" aria-label="Profile: jimmydc98">@<bdi>jimmydc98</bdi></a> Then the clutch is slipping?</p>
]]></description><link>https://dt125r.co.uk/post/6598</link><guid isPermaLink="true">https://dt125r.co.uk/post/6598</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Wed, 17 May 2017 17:13:36 GMT</pubDate></item></channel></rss>
