<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Air box snorkel removed should I upjet]]></title><description><![CDATA[<p dir="auto">Hi I wondered if i could get some help I got my hands on a low mileage dtre I noticed the power valve earthed already boat boost bottles blanked and the snorkel<br />
Removed it actually goes very well and easy hits 75 but it seams to run hot should It be up<br />
Jetted the one in there now is 210 also plan of a full dep pipe thinking maybe I should go<br />
240 main it's a 2007 re I did buy a snorkel to replace it but with it on the bikes loses so much power and response I just don't want it on</p>
]]></description><link>https://dt125r.co.uk/topic/780/air-box-snorkel-removed-should-i-upjet</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 07:13:27 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/780.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 May 2017 17:08:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Mon, 22 May 2017 19:16:06 GMT]]></title><description><![CDATA[<p dir="auto">Mine has the 210</p>
]]></description><link>https://dt125r.co.uk/post/6785</link><guid isPermaLink="true">https://dt125r.co.uk/post/6785</guid><dc:creator><![CDATA[reecesloane 2017]]></dc:creator><pubDate>Mon, 22 May 2017 19:16:06 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Mon, 22 May 2017 16:58:44 GMT]]></title><description><![CDATA[<p dir="auto">Mine runs cleaner with snorkel removed. But its always been slightly rich, and the stock 240 jet seems just a liiiitle bit to big for how my carb is set up.</p>
]]></description><link>https://dt125r.co.uk/post/6769</link><guid isPermaLink="true">https://dt125r.co.uk/post/6769</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Mon, 22 May 2017 16:58:44 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Mon, 22 May 2017 16:56:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reecesloane-2017" aria-label="Profile: reecesloane-2017">@<bdi>reecesloane-2017</bdi></a> How about now?</p>
]]></description><link>https://dt125r.co.uk/post/6768</link><guid isPermaLink="true">https://dt125r.co.uk/post/6768</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 22 May 2017 16:56:42 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Mon, 22 May 2017 14:55:48 GMT]]></title><description><![CDATA[<p dir="auto">No haven't received any mate</p>
]]></description><link>https://dt125r.co.uk/post/6764</link><guid isPermaLink="true">https://dt125r.co.uk/post/6764</guid><dc:creator><![CDATA[reecesloane 2017]]></dc:creator><pubDate>Mon, 22 May 2017 14:55:48 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sun, 21 May 2017 11:08:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reecesloane-2017" aria-label="Profile: reecesloane-2017">@<bdi>reecesloane-2017</bdi></a> Yeah sure mate, as said I do have the correct boost bottle for the inlet over here if you want it.</p>
<p dir="auto">Did you not get my private message?</p>
]]></description><link>https://dt125r.co.uk/post/6738</link><guid isPermaLink="true">https://dt125r.co.uk/post/6738</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 21 May 2017 11:08:14 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sun, 21 May 2017 10:43:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> I'll<br />
Have to buy one the bike came to me without them these arnt my mods but the last owners</p>
]]></description><link>https://dt125r.co.uk/post/6737</link><guid isPermaLink="true">https://dt125r.co.uk/post/6737</guid><dc:creator><![CDATA[reecesloane 2017]]></dc:creator><pubDate>Sun, 21 May 2017 10:43:50 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sat, 20 May 2017 21:46:16 GMT]]></title><description><![CDATA[<p dir="auto">I cut the top off the airbox and rejetted and I did it felt more torque in the higher revs (I had a tmx30 carb with Vforce reeds) even before I installed the 200cc conversion. Sounds great, still very protected from dirt by the seat.</p>
]]></description><link>https://dt125r.co.uk/post/6734</link><guid isPermaLink="true">https://dt125r.co.uk/post/6734</guid><dc:creator><![CDATA[Louis-DT-WR]]></dc:creator><pubDate>Sat, 20 May 2017 21:46:16 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sat, 20 May 2017 21:09:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reecesloane-2017" aria-label="Profile: reecesloane-2017">@<bdi>reecesloane-2017</bdi></a> I lost 10mph off the top-end when I removed the boost bottle, they run much better with them on too. A 230 snorkel will help the air flow whilst retaining the stock inlet method. that option would be much better than having nothing. I would also stick with the 210 jets, the bike was designed to run with those and unless you are upgrading the whole engine, a larger jet is not worth the hassle really.</p>
]]></description><link>https://dt125r.co.uk/post/6730</link><guid isPermaLink="true">https://dt125r.co.uk/post/6730</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sat, 20 May 2017 21:09:04 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sat, 20 May 2017 20:55:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reecesloane-2017" aria-label="Profile: reecesloane-2017">@<bdi>reecesloane-2017</bdi></a> So 210 is fine, put the boost bottles back on should help it not splutter.</p>
]]></description><link>https://dt125r.co.uk/post/6729</link><guid isPermaLink="true">https://dt125r.co.uk/post/6729</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 20 May 2017 20:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sat, 20 May 2017 18:14:58 GMT]]></title><description><![CDATA[<p dir="auto">I'm not after more power but when I put the snorkel on it splutters I was thinking of maybe getting a 230 snorkel I don't like the induction noise but I am used to it with crossers I wish the thing was full standard</p>
]]></description><link>https://dt125r.co.uk/post/6726</link><guid isPermaLink="true">https://dt125r.co.uk/post/6726</guid><dc:creator><![CDATA[reecesloane 2017]]></dc:creator><pubDate>Sat, 20 May 2017 18:14:58 GMT</pubDate></item><item><title><![CDATA[Reply to Air box snorkel removed should I upjet on Sat, 20 May 2017 17:56:35 GMT]]></title><description><![CDATA[<p dir="auto">The bike performs much better with the Snorkel in lol.</p>
<p dir="auto">That induction noise is not good.</p>
<p dir="auto">The bike was designed to run at 210, even with the DEP.</p>
<p dir="auto">The plug will tell you whether you need to upjet. The philisophy is that engines are going to be most performant on the leaner side of things, ensuring all combustiable mix is burnt.</p>
<p dir="auto">You add fuel to cool the piston crown, slow the burn, to reduce the risk of detonation.</p>
<p dir="auto">So unless you have a reason to, leave it standard.</p>
<p dir="auto">I would definitely refit the two boost bottles. Leave the powervalve earthed, get a DEP pipe and keep the snorkel.</p>
<p dir="auto">That's a pretty decent setup.</p>
<p dir="auto">If you want more power then you would want to ditch the carb and air box and get an underslung pipe, Zeeltronic ignition and ported barrel.</p>
<p dir="auto">That's the best way to get power.</p>
]]></description><link>https://dt125r.co.uk/post/6724</link><guid isPermaLink="true">https://dt125r.co.uk/post/6724</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 20 May 2017 17:56:35 GMT</pubDate></item></channel></rss>
