<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help with part list for engine rebuild]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">going to take on the full rebuild soon and I want to order all my parts ahead of time. This is the list I have so far:</p>
<ul>
<li>
<p dir="auto">"Main bearings" (Yamaha DT125R Crankshaft Main Bearing And Seal Kit <a href="http://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Bott.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Bott.html</a>)</p>
</li>
<li>
<p dir="auto">"Gaskets" (Yamaha DT125R Full Gasket Set Athena  <a href="http://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Bott.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Bott.html</a>)</p>
</li>
<li>
<p dir="auto">"Gasket sealent" (<a href="http://www.ebay.co.uk/itm/LOCTITE-515-Anaerobic-flange-GASKET-sealant-GLUE-50-ML-B-B-04-2018/261831854946" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ebay.co.uk/itm/LOCTITE-515-Anaerobic-flange-GASKET-sealant-GLUE-50-ML-B-B-04-2018/261831854946</a>)</p>
</li>
<li>
<p dir="auto">"various Gearbox bearings" (As detailed here <a href="https://dt125r.co.uk/topic/14/gearbox-bearings">https://dt125r.co.uk/topic/14/gearbox-bearings</a>)</p>
</li>
<li>
<p dir="auto">"Crankshaft rebuild service with new conrod"(<a href="http://www.pjme.co.uk/acatalog/Yamaha-DT125R-Crank-Shaft-Rebuilding-Service-.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.pjme.co.uk/acatalog/Yamaha-DT125R-Crank-Shaft-Rebuilding-Service-.html</a>)</p>
</li>
</ul>
<p dir="auto">Should I be buying a new Piston? Or only if it looks visibly damaged when I take it apart?<br />
Do I need to do anything differently or buy any special parts considering I have the athena 170 kit?</p>
]]></description><link>https://dt125r.co.uk/topic/802/help-with-part-list-for-engine-rebuild</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 18:18:36 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/802.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 May 2017 14:06:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help with part list for engine rebuild on Sun, 28 May 2017 15:59:35 GMT]]></title><description><![CDATA[<p dir="auto">And you need to meassure the piston and cylinder for wear, you cant see if fx the cylinder is out of round. Also meassure ring-gap.</p>
]]></description><link>https://dt125r.co.uk/post/6994</link><guid isPermaLink="true">https://dt125r.co.uk/post/6994</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Sun, 28 May 2017 15:59:35 GMT</pubDate></item><item><title><![CDATA[Reply to Help with part list for engine rebuild on Sun, 28 May 2017 15:08:46 GMT]]></title><description><![CDATA[<p dir="auto">You will need Athenas 170 big bore gasket set.</p>
]]></description><link>https://dt125r.co.uk/post/6993</link><guid isPermaLink="true">https://dt125r.co.uk/post/6993</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 28 May 2017 15:08:46 GMT</pubDate></item></channel></rss>
