<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pressure in the coolant bottle]]></title><description><![CDATA[<p dir="auto">My sons coolant bottle cap keeps blowing off with high pressure the bottles been replaced recently by his mate any ideas thanks</p>
]]></description><link>https://dt125r.co.uk/topic/840/pressure-in-the-coolant-bottle</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 14:23:44 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/840.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Jun 2017 11:41:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pressure in the coolant bottle on Thu, 15 Jun 2017 16:29:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jens-eskildsen" aria-label="Profile: Jens-Eskildsen">@<bdi>Jens-Eskildsen</bdi></a> If the bottle is overfilled, it SHOULD just leak out the overflow hose.</p>
<p dir="auto">But so long as the pressure is gradual. If it gets a surge it will rupture the cap.</p>
]]></description><link>https://dt125r.co.uk/post/7321</link><guid isPermaLink="true">https://dt125r.co.uk/post/7321</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 15 Jun 2017 16:29:11 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Thu, 15 Jun 2017 16:01:46 GMT]]></title><description><![CDATA[<p dir="auto">An overfilled overflow bottle can also do this.</p>
]]></description><link>https://dt125r.co.uk/post/7320</link><guid isPermaLink="true">https://dt125r.co.uk/post/7320</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Thu, 15 Jun 2017 16:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 18:01:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> I'm pretty sure mines all good mate</p>
]]></description><link>https://dt125r.co.uk/post/7305</link><guid isPermaLink="true">https://dt125r.co.uk/post/7305</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Wed, 14 Jun 2017 18:01:34 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 16:20:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> That's not really a good idea.</p>
<p dir="auto">When pressure is addded to the cooling system, it WILL find a way out. Since liquids require immense pressure to compress, the easiest option is for the liquid to move to a different location.</p>
<p dir="auto">A nice plastic cap is ideal escape mechanism, requiring little force to actuate.</p>
<p dir="auto">If however it can't escape via there, it will just find an alternate route. Like the thermostat housing.</p>
<p dir="auto">I had this on my Starlet when I bought it. The Fcking bodge jobbers simply removed the thermostat to stop water leaking through there.</p>
<p dir="auto">But water was leaking through there for a reason, the head gasket was blown.</p>
<p dir="auto">Consequently the coolant just leaked out the overflow bottle. And by the looks of it, the coolant had been doing this for some great length of time!</p>
<p dir="auto">So let coolant blow out the bottle, rather that than through the radiator core.</p>
<p dir="auto">But better still, fix the problem.</p>
]]></description><link>https://dt125r.co.uk/post/7301</link><guid isPermaLink="true">https://dt125r.co.uk/post/7301</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 14 Jun 2017 16:20:27 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 15:29:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johncroz" aria-label="Profile: johncroz">@<bdi>johncroz</bdi></a> turned out my head wasn't tight so I think that was my problem but I still keep the tie on just in case</p>
]]></description><link>https://dt125r.co.uk/post/7297</link><guid isPermaLink="true">https://dt125r.co.uk/post/7297</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Wed, 14 Jun 2017 15:29:47 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 14:39:43 GMT]]></title><description><![CDATA[<p dir="auto">Cheers for the advice</p>
]]></description><link>https://dt125r.co.uk/post/7296</link><guid isPermaLink="true">https://dt125r.co.uk/post/7296</guid><dc:creator><![CDATA[johncroz]]></dc:creator><pubDate>Wed, 14 Jun 2017 14:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 13:47:42 GMT]]></title><description><![CDATA[<p dir="auto">It's going to be head gasket.</p>
<p dir="auto">Quick way to test is see if there is any oil in your radiator.</p>
]]></description><link>https://dt125r.co.uk/post/7294</link><guid isPermaLink="true">https://dt125r.co.uk/post/7294</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 14 Jun 2017 13:47:42 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 13:09:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johncroz" aria-label="Profile: johncroz">@<bdi>johncroz</bdi></a> however this can be a sign of head gasket failure and some other pretty serious stuff so I don't reccomeny doing what I did but each to there own</p>
]]></description><link>https://dt125r.co.uk/post/7293</link><guid isPermaLink="true">https://dt125r.co.uk/post/7293</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Wed, 14 Jun 2017 13:09:04 GMT</pubDate></item><item><title><![CDATA[Reply to Pressure in the coolant bottle on Wed, 14 Jun 2017 13:03:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johncroz" aria-label="Profile: johncroz">@<bdi>johncroz</bdi></a> happened to me so I cable tied the lid down with good results</p>
]]></description><link>https://dt125r.co.uk/post/7290</link><guid isPermaLink="true">https://dt125r.co.uk/post/7290</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Wed, 14 Jun 2017 13:03:41 GMT</pubDate></item></channel></rss>
