<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[can only select 2 gears.]]></title><description><![CDATA[<p dir="auto">hi guys was wondering if anybody could point me in the right direction.<br />
took the bike out this afternoon and it went to 4th gear no problem,downshift to 3rd no problem but thats it thats all the gears i have now.<br />
havent had any indication in the past that there has been anything wrong.<br />
tried adjusting the clutch cable and there is oil upto the mark in the window.<br />
thanks for in advance for any ideas</p>
]]></description><link>https://dt125r.co.uk/topic/843/can-only-select-2-gears</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 19:59:41 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/843.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Jun 2017 16:23:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to can only select 2 gears. on Mon, 26 Jun 2017 17:46:39 GMT]]></title><description><![CDATA[<p dir="auto">big thanks for all the replys.got it all running today.replaced the clutch as well.cheers</p>
]]></description><link>https://dt125r.co.uk/post/7498</link><guid isPermaLink="true">https://dt125r.co.uk/post/7498</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Mon, 26 Jun 2017 17:46:39 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Tue, 20 Jun 2017 18:54:48 GMT]]></title><description><![CDATA[<p dir="auto">Yeah just remove the clutch, simple job.</p>
<p dir="auto">Question is, why has it moved</p>
]]></description><link>https://dt125r.co.uk/post/7411</link><guid isPermaLink="true">https://dt125r.co.uk/post/7411</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 20 Jun 2017 18:54:48 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Tue, 20 Jun 2017 16:26:56 GMT]]></title><description><![CDATA[<p dir="auto">Think you will need the whole clutch off to replace that. Just remove the gear shifter from the spline and see if you can wriggle it out first.</p>
]]></description><link>https://dt125r.co.uk/post/7409</link><guid isPermaLink="true">https://dt125r.co.uk/post/7409</guid><dc:creator><![CDATA[Mightyman]]></dc:creator><pubDate>Tue, 20 Jun 2017 16:26:56 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Tue, 20 Jun 2017 16:05:29 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.imgur.com/Dku7tmQ.jpg" alt="0_1497974599328_IMAG0761.jpg" class=" img-fluid img-markdown" /> had the time today to open the gear box cover.turns out the problem is a broken return spring.<br />
my next question is how do i get to it?</p>
]]></description><link>https://dt125r.co.uk/post/7408</link><guid isPermaLink="true">https://dt125r.co.uk/post/7408</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Tue, 20 Jun 2017 16:05:29 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Mon, 19 Jun 2017 17:55:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/castrolsniffer" aria-label="Profile: castrolsniffer">@<bdi>castrolsniffer</bdi></a> am waiting for a clutch to be delivered and am going to give it a go</p>
]]></description><link>https://dt125r.co.uk/post/7399</link><guid isPermaLink="true">https://dt125r.co.uk/post/7399</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Mon, 19 Jun 2017 17:55:32 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Thu, 15 Jun 2017 21:01:09 GMT]]></title><description><![CDATA[<p dir="auto">Just remove ur clutch first to see if it's a clutch issue,it could be a collapsed clutch BB etc</p>
]]></description><link>https://dt125r.co.uk/post/7323</link><guid isPermaLink="true">https://dt125r.co.uk/post/7323</guid><dc:creator><![CDATA[castrolsniffer]]></dc:creator><pubDate>Thu, 15 Jun 2017 21:01:09 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Wed, 14 Jun 2017 20:58:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> yes i think the engine is going to have to come out to have a look.think i was secretly hoping for the easy fix.<br />
thanks for the replys</p>
]]></description><link>https://dt125r.co.uk/post/7317</link><guid isPermaLink="true">https://dt125r.co.uk/post/7317</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Wed, 14 Jun 2017 20:58:10 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Wed, 14 Jun 2017 18:57:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/admiral323" aria-label="Profile: admiral323">@<bdi>admiral323</bdi></a> Yeah they look like dog ears.</p>
<p dir="auto">I've just been looking into this, not sure how you would only get third and fourth.</p>
<p dir="auto">third and fifth maybe. But not sequential gears since it doesn't work like this.</p>
<p dir="auto">I'm afraid it's going to be an engine out jobby and split cases if you really want to find out....</p>
]]></description><link>https://dt125r.co.uk/post/7311</link><guid isPermaLink="true">https://dt125r.co.uk/post/7311</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 14 Jun 2017 18:57:56 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Wed, 14 Jun 2017 16:30:06 GMT]]></title><description><![CDATA[<p dir="auto">selector forks?</p>
]]></description><link>https://dt125r.co.uk/post/7304</link><guid isPermaLink="true">https://dt125r.co.uk/post/7304</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Wed, 14 Jun 2017 16:30:06 GMT</pubDate></item><item><title><![CDATA[Reply to can only select 2 gears. on Wed, 14 Jun 2017 16:26:01 GMT]]></title><description><![CDATA[<p dir="auto">If I had to guess, it'll be the dog ears.</p>
]]></description><link>https://dt125r.co.uk/post/7303</link><guid isPermaLink="true">https://dt125r.co.uk/post/7303</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 14 Jun 2017 16:26:01 GMT</pubDate></item></channel></rss>
