<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[dt125 valving problem]]></title><description><![CDATA[<p dir="auto">Help needed my dtr125 was valving fine when I first got it and now it just doesn't valve I tried a wheelie and it just has no power it's struggling when it hits 7000rpm and splutters I can just get 60 I'm not to sure what it could be I tried a wheelie the other day just got it up and then it dropped and next thing I knew my bike was valving at around 5-6000rpm and was absolutely flying lifting through first second and third put it in for on it the next day and it hasn't worked since could it be my valve?</p>
]]></description><link>https://dt125r.co.uk/topic/90/dt125-valving-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 09:36:45 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/90.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Dec 2015 08:48:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to dt125 valving problem on Fri, 25 Dec 2015 12:42:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi there Tommy.</p>
<p dir="auto">By Valving fine I presume you mean the powervalve, since there are no valves in a two stroke engine.</p>
<p dir="auto">What years your DT?</p>
<p dir="auto">How is the condition of the battery?</p>
<p dir="auto">Does the valve do the cleaning cycle upon turning the ignition on and off.</p>
<p dir="auto">What condition is the engine in? Miles travelled etc.</p>
<p dir="auto">Have you tried pinning the powervalve to see if that rectifies the revving issue?</p>
]]></description><link>https://dt125r.co.uk/post/375</link><guid isPermaLink="true">https://dt125r.co.uk/post/375</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 25 Dec 2015 12:42:27 GMT</pubDate></item></channel></rss>
