Clutch cable brand
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F143032536486
Has anyone tried this brand of clutch cables? I'm so tired of hard clutches. I've tried lubricating my old but with no results. It appears to be worn too.
@Louis-James Where is the double thumbs up button? @admin sort it out!
@Irongamer727 Softer springs.
To be fair I've not struggled with a cable clutch. If it's really stiff then it sounds like you've got something wrong.
@Calum Venhill is the UK distributor for Magura Hymec clutches amongst other things. AS3 are a supplier of aftermarket and performance parts for various manufacturers, similar to Apico. I have not used their products personally so I cannot say if their any good or not. OEM tend to be better quality and generally last longer than other brands.
How does the price compare to an OEM cable? As with everything in life you only get what you pay for and quality does not come cheap. Having said that you could always buy it and let us know how you get on with it??? ;) ;)
@Irongamer727 An OEM clutch cable for my Aprilia MX 125 costs £25 + shipping. So I would say that's a decent price, especially as it has teflon inner lining and stainless steel wires, do the OEM cables have those? I'd give it a try if I was you. :winking_face:
@Calum said in Clutch cable brand:
To be fair though, I did become the boss of that back in the day!
I always run aftermarket cables on my bikes, no problems ever, i just buy the cable, buy the cable housing, the cable ball thing just like the throttle has but bigger(forgot the name ._. ) , cut it and make it on my own, really easy, never had a clutch cable snap or even fray on me..
Never had problem with non-original cables. I give them some light oil, and make sure to route them with a minimum amount of kinks. Often you can reroute them differently to get them even smooter.
But go eom if you feel like it :)
Found oem lines £20 as well
@Irongamer727 Decisions, decisions, does the OEM have the teflon lining and stainless steel wires???
