What was I thinking!…
Damn, I still have expensive hobbits! 🙄 😛
I did a quick search and the forks you can unscrew have a fixing/grub screw on the inside of the fork bottoms. Mine has that. It’s not the Paoli fork. It’s a steel upper (not gold ally) and it has the fitting for a calliper on the throttle side leg bottom as well, as does the wheel for a disc! Tzr250 3xv right callipers are like unicorns sh1+ though, but there are 4pot Triumph ones that apparently fit for a good price.
I digress! It does mean I can strip them if I can find stachions (39mm) for a reasonable price. £180 is all I’ve found so far…Cheers guys!…
P.S. I’m embarrassed to admit, but I’ve used JB weld chemical metal to fill in pits on stantions before in my yoof! It worked for as long as the bike did 🙂 which wasn’t too long. £150 for a CDI was a lot of money in 88! 😐 …
It was definitely more than the bike was worth! 🫤 -
@OllieDTR I use Flickr to post up pics on here. Choose one out of your photostream, click the download icon and choose "view all sizes", then right click the picture and choose "open image in new tab". Copy and paste the URL from that webpage into the image link on here (7th from the left). Front end looks good :+1:
@SpookDog There are places that can re-chrome fork stanchions, only a few in the UK as they're hard chrome which I think has to be ground back to the correct OD unlike the more common soft chrome which is what is used on grab rails etc. and not up to being a bearing surface (and apparently you can't use hard chrome for decorative items either).
I wonder if you could run R1-type blue spot calipers? They seem to fit anywhere on Yamahas those older type Sumitomo calipers were used originally, lots of people retrofit them to TZR/TDR250s etc. I've never done anything with them but @Stevie-Wonder rebuilt a set on an FZS600 Fazer and might be able to advise further? Probably easier to find secondhand and would make for one seriously trick TZR125R :alien:
This post is deleted!
Thank you for explaining mate I’ll give it a go now
Cheers bud, I’ll look into them! The disc are east enough to find. Imagine the confidence two 11inch floating discs & four pots will give! No modding, just replace the master and bolt it all on! 🙂 …
I might know of an old belgarda going that a lad wants £500 for. I haven’t seen it but you can imagine it’s been well used 😛 …
Edit:
Looks like it’s more expensive to hard chrome than to replace with Paolo stanchions… -
If anyone can find a ‘how to’ vid or manual, or anything about dismantling USD 4hw non adjustable forks, can you please let me know. I’m 99% confidant in my doing it on the fly, but I’d rather learn from someone else’s mistakes 👍 …
I am lazy but I have looked… -
@SpookDog Have you tried Simply Bearings? Those bushes are a pretty common engineering component after all, if you know the dimensions of the stanchion and where they fit, they or another bearing supplier can probably help.
No I’ve not tried them yet. I’m don’t know what the dimensions are, I can’t find them. I don’t have the tools to measure the existing bushes properly, to the 10th of a MM. i learnt that it matters the hard way last time! 🙂 …
The fork stanchions are 39mm, the depth of the bush is 20mm, the outer edge looks to be 42mm. I’m guessing the thickness of the bush is a bit les than 1.5 mm, but don’t know for sure and can’t find anything similar…
Edit: nope, can’t even find any bushes on their site 😐 …
Inner
Outer
Depth
I can’t find anything even when I search these sizes with ‘guide bushes’
I don’t know what to do 😐 …If any web search Jedis’ can help it would be sweet!…
I can’t even get the’search by size’ option to come up @ Brooks suspension anymore!!…
Still no joy with finding the fork bushes. But!
On another subject: This is the clutch side crank spacer that fits inside the clutch side crank seal:
Clutch side crank spacer doohicky:
Are these (two lines) wear marks or are they machined to give a better surface for the seal to ‘seal’ against?…
I don’t know whether to put it back the way it came out because the seals may have different dimensions…On my old dtr lump they looked like wear but these look more ‘purposeful’. Any advice…
