TDR issue
Sounds like the engine is very tight to me from the rebuild. Hard to tell from a YouTube video
Looks like you are making good progress though mate :)
Check my vid , same sound
Never been posh enough to have an electric start DT so wouldn't know ;)
Yes looks good in that color scheme :)
@tdrnoob first thing I did was removed starter motor to see if its really that problem and it was. I had a broked bearing stay. Thats a plate behind a flywheel where starter clutch sits on needle bearing . I am replaced it , cleaned and lubed everything in there and its ok now.
Number 1 was broken .
@nottsbiker Not sure if it is tight as it is my first bike :/
Also I have changed the old air filter and cleaned the carb properly.
Good progress because of wanting to ride and commute to work.
I bought it back in may and since then made only 100 miles.
Did you get it from Unit 5 Motos? Seen one like yours on their Facebook page with one black side panel on an otherwise red TDR.
I'm in France at the moment and there are loads of Belgarda's for sale here, mainly our model with wire wheels in various conditions from €600 upwards. Typical I'm skint :(
@nottsbiker Yes I did. :)
I was following them and waiting for something special like this.
On which french website you are searching for those Belgardas?
Lebancoin
You will struggle to find anyone willing to post to the uk and the shipping rates are crazy from here.
Loads of lovely WR200's out here too ;)
J'ai trouvé une annonce qui devrait vous intéresser sur leboncoin
An example of a colour scheme I really like the look of;
@nottsbiker That is sexy
Another update with the brand new issue
Cold bike. I couldn't start start it. It didn't accept the throttle. Started with the choke only. When warmed up everything worked fine with the choke off.
Spent about 10 minutes on adjusting the carburetor air screw (to get the highest rev on idle)
Noticed that the bike is heating up a bit to fast. (Heat arrow pointed at 3/4)
Decided to go for a ride
In the beginning accelerated well, after 2-3 minutes started to feel like something is dragging behind.
Engine was running very slowly and it didn't accept the throttle.
I stopped and noticed that in neutral gear is hard to push bike forward of backwards. Looks like the engine is tight?
When it gets colder then gets back to normal.
Video
https://www.youtube.com/watch?v=KV5ynUc5-xw&feature=youtu.be
Any thoughts?
Regards
