What damage have I done?
https://41.media.tumblr.com/tumblr_m9y7xwQ8CS1rfm9s8o1_540.jpg
Literally just paste the image location. Nothing else required.
http://s1377.photobucket.com/user/MatthewT47/library/?view=recent&page=1
Don't know what's going on now, hopefully you can view it here...
Thanks again
Edit: I give up, removed http from link
I had another look at the bike this evening, and although nothing looks to have gone top end - there is a lot of play on the connecting rod. Side play tolerances I have not looked up yet, but i'm almost certain that there shouldn't be at least 2mm play up and down!!
If that's gone south and it means splitting the engine is this cost effective or am I flogging a dead horse? Would be such a shame as I really love the little beast!
Yep not a problem mate.
There should be no up and down play. And little side to side play is to be expected and within tolerance.
Sounds like the engine needs to be stripped down.
Again this is standard practice for two strokes and is incredibly simple job to do.
No real specialist tools required othwr than the crank will need to be sent away for a rebuild.
The rest of the engine can be rebuilt at home.with basic tools. Only a flywheel puller, clutch holding tool, torque wrench and a rubber mallet will be needed.
The bearings can be removed and inserted by placing the engine in the oven for a few minutes and letting the metal expand which will release the bearings. The rest is just simple stuff.
The most complicated bits will be rebalancing the engine. Which is self explanatory. Just matxh up the notches on the primary drive vogs. And balancing the clutch, which I have documeted here.
After thay it is just a case of using decent gaskets and genuine or Athena headgasket. Personally I would buy a full Athena engine gasket. And take lots of photos.
Simple.job
OK well it looks like I will be doing a crash course in mechanics then!
So apart from the tools you listed, is this what I should be getting?
Full gasket set (Athena)
All bearings
Piston kit
Crank rebuiltThinking about it, do I also need to take cylinder somewhere to be measured/checked incase of re-bore?
Thanks,
Matt -
I would get the cylinder honed against a new piston. You will need to have a new piston to hone against. I would let whoever is doing the honing buy the piston. Or ask them if it needs a rebore. If they say no then buy the same sized piston.
There is probably a few tools I missed off the list. A good set of spanners and screwdrivers. So nuts and bolts to replace the ones you use is not s bad should.
Yeah, get it to a shop and ask if you will be fine with a hone. In my experience you don't tend to save much money by buying the piston yourself.
I mean sure, if you can get the piston cheaper then by all means. But the risk of buying the wrong one could outweigh the savings you might make.
OK so not much progress since last post, but I have now at least removed engine from the frame...
Still not made it to a shop to check cylinder, but have ordered a flywheel puller and made up a holding tool for clutch/flywheel which I'm chuffed with!
All prepped and ready to operate after a good clean. B-)
Well I finally got myself organised and have everything ready for the rebuild 7 months later! :-S
Crank has been rebuilt (not by me!), barrel/head skimmed, powervalve cleaned, got full seal kit and full Athena gasket kit ready to go... Now I just need to remember where everything goes. :-))
Ok, so my next silly question is... How do I remove seals the correct way to avoid damaging anything?!
Think I have read that you can use screws to give yourself something to pull on - is this correct? Not keen on digging them out with a flat-head (unless they pop out easily).You can probably tell I'm a bit nervous about the whole thing, guess I need to man up haha! :-P
Ah, makes sense thanks!
There was me thinking I had everything on my rebuild list, and I forgot to get the other bearings...
All remaining bearings seem to be in great shape, but I guess I need to weigh up whether or not to do a full rebuild without all new bearings. Is it worth the risk?!
I only have the 2 main bearings for Crankshaft, and the top end stuff.
I'll have to commandeer the oven once my wife has gone to bed, and get them all out and have a proper look at them! They all feel/look in good nick but I might as well take them out anyway to make the seals easier to change.
