Tight crank shaft nut
So I'm doing my first engine rebuild and I'm stuck at undoing be crankshaft nut, I cannot get it to move, is it supposed to be extremely tight? The one on the other side wasn't anywhere near as tight.
@LJK_hunter The othet side has a tab washer to stop it coming undone. The flywheel nut should be tightened to 60nm approx. Although it's possible that it's has tightened due to the reciprocating mass of the wheel.
There wasn't a tab washer on either side but this is the side that's tight.
Got the nut off now, used
@MIGHTYMAN 's advice and put the engine back in the frame. Thanks guys :)
