engine piston check
hey @SpookDog i was wondering if what happened could cause my crank bearing go bad as someone told me that, is there any way i can check that, i was thinkit that the water that got in caused corrosion on the bearing or something, i just don't want my engine to go boom haha
I’d be more worried about you crank if it’s as bad as you say!… -
You should be able to rotate the stator easily by hand. It shouldn’t make any rumble noises or feel clicky/notchy when you turn it…If you gently lever the stator up and down it shouldn’t have any free movement. It might flex a bit if levered too much…
Thanks for the info! -
it could be easily turned by hand and it has no movement up or down neither side to side no clicking no nothing just a little friction noisse wich i think is coming from the piston as its not in a good condition -
@SpookDog yo one last thing i made a video today of kicking the bike over just so you can hear the bike make that friction noise to know if the crank is good, idk maybe just my stress is making me hear it or idk here is the vid https://imgur.com/gallery/HRIy3mb
