PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,)
And now this thread is up to present date. I am making a few changes, removing lots of stickers, tidying up, rewiring and the new wheels to go on when I have time.
Can't wait to have these on :)
Wheel spec:
Hubs powdercoated in gloss metal gold.
Rear rim width upgraded to 2.15
Silver alloy rims
Stainless steel spokes and nipples
Fitted with Continental Twinduro TKC 80 tyres with 140 on the rear!! Yes it will fit!
I didn't want something too much MX style but a perfect trailbike tyre (mostly for appearance because it is a DTR ;)
@Louis-James love the fact you stayed trail though. I love sm's but the world is saturated in really good sm builds so it is so refreshing to read something different.
Today I fitted the mesh to the new rad scoops
Also fitted these :)
Grips on.
Just bought a luggage rack, will be powdercoated in white to match my frame. Also re-fitting my front brake disc guard afters it's painted in blue.
I want to make this look more the original trail bike it was by fitting these original parts
Is this original front calipers except the carrier?
http://s.aliexpress.com/2Av2i2Iz
(from AliExpress Android) -
@Calum most yamaha parts are made in Taiwan or China these days and China has really caught up with quality, I bought my brake discs off AliExpress and they are just as good as the ebc ones I had. And the caliper looks identical, it's cheaper than a rebuild kit :)
To do list:
Powdercoat luggage rack in white.
Fit new rad scoops (I will do this last to avoid scratches)
Fit skid plate / sump guard once powdercoated
Paint front brake disc guard blue and fit
Fit 17t front sprocket
Fit new wheel!! When I get new center spacers.
Fit stiffer clutch springs, (I think it was slightly slipping with all the extra power)
Also be fitting these once powdercoated in blue, (need to modify because the Kickstart hits)
Just prepped and primed this, why is it so large?
An xt600 one fits closer to the disc
Got to have the model logo on display ;)
Toast rack came in the post today, also ordered the frame guards
Got this back from powdercoateding, I won't fit it until the wheels are on, gets in the way for jacking up.If you're fitting frame guards you need to tap the swingarm pivot bolt to M8 like shown.
Also here's my granny rack
@Louis-James where did you get the sump gaurd from?
@Louis-James Very nice.
Yeah I have made one for mine. But I rolled the pan so that it follows the contours of the frame. Frame gaurds are nice.
Small progress
Modified for Kickstart clearance
Need to take some bits to powdercoaters
Got my parts back from powdercoateding, I have fitted the frame guards now :)
