DT200WR restoration project pic heavy
The trick to make any project look good is attention to detail... including deep cleaning.
See how well these 25year old parts come up.
Here's the engine.. I am not painting the crankcases as they were bare from the factory,but I'll give a light polish before installing to frame.
Took ages to clean it to this standard.. especially around the sprocket, exhaust manifold and underneath..
I also sourced a 125re 2t bottle which I will use as I cannot find the original one.. the level sensor connector is the same, so hoping that will work. Also the oil pump is in good condition and the carburettor has the oil intake fitting. I will use clear hoses as always.
The side stand switch is missing but I have found the wires for it.. so I will fix this.
Radiators are in such good condition.. but these bikes do not have any braces to protect them unlike the 125
New fork guards came..
So some new bits came π
Rear wheel before my gf spent 2hrs cleaning
After
This bearing was damaged so pressed it out.. just trying to source a new one
Also cleaned up the fuel tank and wiring loom OCD style.
Probably lost 1kilo of dirt and grease from the bike
@Louis-James The rear wheel looks totally transformed, top job by your misses. What products did she use to achieve those results???
@NINJA said in DT200WR restoration project pic heavy:
Mostly elbow grease haha, sprayed in multi purpose spray (wd40 type stuff) left over night then she used a tooth brush and scotch bright+ brake clean and hand polished
@Louis-James Know anyone with a Lathe? Collar wouldn't be hard to make.
Without this seal , you might as well not have an air filter. So I made a new one
New twin air filter on the way..I literally spent a hour cleaning bolts an fitting... But it has to be done π
Even though the seat cover was in good condition, I wanted baby blue + Yamaha logo
One of my least favourite jobs... 2hrs of tweeking..
I will let it shape over the weekend and then give it a final stretch.I like the red to match the forms and purpose to match the frame.. the graphics are blue and purple so the seat will make sense.
Shock absorber came up nicely (no paint ) might consider re painting spring
And this arrived.
@Louis-James Oh wow, be almost criminal to use that!!!
