Stevie’s French '98, Mid-90's WR/YZ/DT (An idiotproof guide to building your own DTR)
Thanks @Calum , took long enough.
![alt text(https://i.imgur.com/NWF4AKq.jpeg)
Took her out for her first solo outing since the MOT.
Once again, still can’t get over the fact I can actually look down once again and have the clocks working. I think the bulb for full beam indicator has gone though as it’s no longer coming on with the lights. Very minor issue though.
Of course I didn’t spend the whole time on the road, didn’t wouldn’t be much fun.
Who’s a pretty gal’
The temptation with the tide being out to attempt crossing the causeway behind me was great. Did I fancy chancing getting stuck or breaking down in the middle of an ocean on my first outing though? Not really… I admit I pussy’d out 😂It’s on my bucket list of things to do on my bike so I’ll do it one day, hopefully with a GoPro or something.
I must say it’s good to ride her once again. I forgot how big she is, it’s been so long I’m still comfortable riding her again.
The bars feel super wide and I thought I remember the forks being stiffer. For some reason the forks feel soft and dives quite a bit when braking, I don’t remember it being that way but then again it’s been so long since I rode her I don't trust my memory. With no signs of leakages from the fork seals or anything else being different since it was last used I just have to assume it was always that way. Once again it’s probably me but I’m still going to check how much oil is in the forks.
Mechanics wise/issues, I cleaned up any oil I’d found and think I’ve found the causes.The washer for the coolant doesn’t look like it’s the right size and isn’t sealing properly. I’ve torqued it to spec and am going to order another NOS copper gasket.
The oil drain bolt was also loose, I’ve torqued it up to spec and am going to keep an eye on it.
I also found a second culprit for where motor oil was coming from, the gear shift shaft oil seal was seeping oil.
(You might be able to see a little bit at the bottom)
I imagine this is easy enough to replace though, is it a case of draining gearbox oil out, take off the shifter and then using a hook/pick to pull the seal out and then pushing the new one in?The 3rd source of the leaks is blue oil indicating two stroke oil, my two stroke oil pump / autolube has leaked a little bit for a good while now but I’ve not bothered to investigate. Something that I do plan to do now.
If anyone could point me in the right direction as to what could cause it or where to look I’d appreciate it.
The last and main issue I’ve found from my outing is the fact that the bike point blank refuses to rev out past 7k into powerband.I’ve whipped the exhaust off and checked I set the powervalve up correctly and that the servo’s operating as it should.
With the pulley lined up with hole the valve sits flush in the exhaust port and the servo cycles fully and all that jazz. From what I remember that means everything in regards to the YPVS is setup as it should be.
The only other things I could think that’d would stop it revving out into powerband would be.
- low compression (given the fact the bikes starting to take a couple more kicks then usual to start means a compression test is well worth doing)
- Blocked main jet, I don’t fancy pulling the carb off so I might ride to the bypass and hold the throttle wide open and hope for the best. It’s done the job in the past and it’s been a long ass since time since I’ve wrung her neck.
- HT Coil or Lead, I’ve got no experience in this department so if anyone could tell me how to test if it’s failing or what to look for I’d appreciate it.
When revved it feels like it wants to go and you feel it starting to make power (enough to spin the tires up in mud or anything loose and enough pop the front end up on demand when warm) down low but as soon as you go wide open throttle and are about to go through powerband it gets to 7k and tries to rev it but coughs and splutters with the needle jumping back and forth around the 7k mark.
So, some teething issues to get sorted and fettling to be done but fingers we shall get them fixed soon.
Even reset my trip clock whilst I was out, something to keep me smiling and to think about how much I’ve used her since her first proper outing.Hopefully ya’ll enjoy the photo’s, now the bikes back on the road it was one of the main reasons for the adventure! I’ll be looking forward to your replies/help so I can iron out the issues and have even more adventures!
@Stevie-Wonder Looking good, USD front end with a speedo cable reminds me of the KDX125SR or RMX250. Nice spot to take some pics as well :+1:
Definitely keep an eye on the oil drain bolt. These are very soft and visibly stretch when overtightened, it was Yamaha's intention to spec the bolt like this IMO as it means if it's done up too tight, it will always snap the bolt rather than wreck the thread in the crankcase whereupon you can just pop the clutch cover off and wind out the broken part with pliers etc. I must admit I speak from experience here as I repeatedly overtightened the drain bolt on my 1990 I owned as a teenager and then sold it to a mate, and the very 1st time he changed the oil it snapped! So I felt duty bound to go over and help him repair it, we removed the engine assuming we'd have to split the crankcases to get the thread repaired, and then fortunately it just unwound so we could just put it back together. The genuine drain bolt is like £2 from Fowlers so again, well worth buying genuine (including a few copper washers) because if you go and get a really strong bolt and then overtighten it by mistake this could make the difference between an easy repair and a complete engine rebuild. Torque setting is 15Nm IIRC (check this) so another job for your 1/4" drive torque wrench.
I know I always say this but a DTR fourstroking at medium engine speed is almost always a blocked emulsion tube (the brass tube the main jet screws into) so I'd look here first. Tap it out and make sure all the holes are clear as these get blocked with moisture/crud and it just starts fourstroking one day. HT lead breaking down is also possible but when this happened to me it started at very high rpm like 9000+. Definitely do a carb clean even though it's a PITA I know. Also check the air supply for the emulsion tube, it's the brass tube on the right rear of the carb body just in front of the carb-to-airbox rubber. You should be able to blow through this, but only just.
Autolube leaking I would just do an oil pump recon as the Yambits kit contains all the seals and gaskets you need to completely recondition the pump, including the gasket where the pump body joins the crankcase. Do this and replace the ball and spring kit where the delivery hose attaches, clear delivery hose and a new supply hose from the tank (retain and re-use the spring-like sleeve this passes through) and you're golden. One thing about the Yambits clear oil delivery hose is, it's slightly thicker walled than the OEM hose and quite a tight fit through the rubber grommet where it comes out of the oil pump housing so 5 minutes with a Dremel and you can make this a nice snug fit which still doesn't allow water ingress.
The gearchange shaft seal can be replaced without removing the shaft if you're careful to avoid marking the shaft. First give the entire area a good toothbrush/Jizer clean to remove all chain lube/road grime from the exposed part of the shaft, and clean this up with wet and dry to remove any rust/sharp edges which might rip the new seal during installation. Then what you have to do is go to a model shop and get some 1mm Lexan offcuts from RC car bodyshells, cut off a small section and jam this between the old oil seal and the shaft to protect the sealing surface as you lever the old seal out. Lexan is flexible yet tough and it's not uncommon for a bodyshell to still look good after a season of crashing at scale speeds of 400mph+ so it's ideal for this, this also works on crank seals.
I also forgot to mention whilst checking the powervalve I found that the whole valve had play in it.
Whilst the top end was other I give the valve area a proper good clean out of all the gunk carbon and oil that’d built up over time and replaced all the seals
Also thanks @HOTSHOT-III for the tips. I will report back my progress etc when I’ve got the parts.
Side to side is ok. It’s up and down play that you don’t want…
I’m
Didn’t someone else have the exact same problem with the emulsion tube a couple weeks ago? Hard to start and bogged out at open throttle?…
My memory isn’t like it used to be 🤪
Update,
I’ve checked the air filter and as suspected it’s still like new.
I’ve removed the carb which is still also like new, before the bike went bang and stopped getting used I had Jim Bailey drill out the AFR screw as it’d seized and also refurb the carb. I checked the emulsion tube too, not a single bit of dirt.
I also did a few compression test’s and I’ve got really good compression.
3-4 tests and every single one coming a touch under 120psi with the engine stone cold. Pretty impressive.Also sidenote does anyone find it a right asshole getting the compression tester into the spark plug hole? I was having a right mare 😂
The coolant and trans fluid/oil leaks seemed to have stopped too. The only fluid I could find was blue. None the less I’ve bought a couple OEM copper washers. Even if I don’t end up needing them they’ll get used eventually.
I had noticed some fluid around left side crankcase gasket but that was blue as well (same colour as putoline mx5 two stroke)
There wasn’t any trail showing how it got there though? Odd… Had me wondering if the trans oil could get dyed blue from the gasket?? Then I realised that’s just silly.
I also made a job of trying to fix the OEM fuel tap.
EBay replacements do the job and are nice and shiny but the material quality is sub par by comparison. Just look at the erosion on the copper.
My other gripe is your reserve leaves you with about 5-10 minutes worth of riding to get to a petrol station or you’re fucked.Unfortunately things didn’t go to plan.
I found out the hard way the petrol cap isn’t watertight.
Between the tank being upside down whilst I repeatedly fit and took off the pet cock and it sitting upside down I ended up losing 3/4 of a tank of fuel. By the time I’d realised it was too late. You can’t help but laugh.To make matters worse no matter what I tried with the original petcock I just couldn’t get it to seal.
Where it screwed into the tank was fine but petrol would piss out with the Cock left on Off position. Further inspection showed the tiny little metal washer that goes between the two rubber pieces was all bent in multiple directions I assume this was stopping it seal properly.
Unfortunately you cannot buy this washer anymore, I’m kicking myself now though as I should’ve tried to see if the repro one had a washer identical or similar I could’ve used
Either way it still doesn’t make sense to me as it didn’t just leak a little bit fuel pissed out like the tap was on.
Im also missing the filters, pretty handy if you don’t fancy having the carb off every 5 minutes.
The more I type the more it sounds like buying a new OEM replacement sounds like a good idea. Unfortunately they’re £75-85. A lot of money I don’t currently have
Long story short what was meant to be a 5 minute fix ended up being a ball ache. If anyone finds a good condition OEM replacement petcock / fuel tap or has one laying around I could buy I’d be forever grateful.
Now that the bikes on the road I really want to get the miles in and enjoy her once again only issue is I used to run out fuel often enough with the old petcock which gave you a fair warning so I don’t fancy my chances with the repro one 😂.
Gear shaft seal is still leaking but barely enough to form drips. It needs fixing for sure but I can get away with neglecting it for a little while until I can order a new OEM seal.
The gear shaft also has some play side to side, I’m guessing this indicates a worn bearing? I’m not surprised being honest as my gear lever took quite a bit of the impact. Still though it’s not doing any harm or causing any problems.
I also had couple spare plugs laying around, I took the old one out which was blacker then the midnight sky and put a new one in.
This seemed to have made a difference as I noticed the bike fired up first kick.
Even better I could start her without choke, my old method of a few priming kicks, one more to get TDC then one big kick holding the throttle wide open done the trick and she comes to life.
Unfortunately I didn’t get a chance to go for a test ride. I thought I was done but some silly twat (aka me) forgot to remove the carb warmer hoses and didn’t realise until they’d got the carb half way out of the bike. Not fancying wrestling with it to get it bike I removed them in situ. This led to coolant running down the manifold and into the reed cage so that all had to come out and get cleaned as best as I could before reassembly.
Said silly twat then puts it all together goes to ride off only for the bike to begin revving its tits off from idle. At one point I’d even hit the kill switch only for nothing to happen.
Having spent 6-7 hours working on the bike at this point, I shit myself and let out the biggest sigh you could imagine. I wasn’t happy. Was my engine running away or had my kill switch gone faulty?
Luckily my brain went “did you tighten both sides of the manifold?” I reached down and you could feel the force of air being sucked from underneath the manifold into the reeds.
As annoyed as I was, I was just as relieved as the last time this happened it was time for new crank seals 😂.
I also have no idea why when I hit the kill switch she kept running, I turned her off using the keys kicked her over and tried again and the kill switch worked. Very odd behaviour… especially with the kill switch being magnetic, there’s nothing to really go wrong.
Anyway I go to tight the bolts for the manifold and you wouldn’t believe it? My 10mm is missing. Yes. You heard it right. It’s not a meme, it genuinely happened. For fucks sake, you couldn’t make it up.
It wouldn’t even be an issue if it wasn’t for the fact I’d put everything together so there was absolutely no chance of getting a socket in there, I managed to use an adjustable wrench to do up the top left bolt furthest from the carb which fixed the air leak and settled the idle and ordered a new 10mm spanner.
Just as I thought I was done I noticed a puddle of coolant forming underneath the bike. “FOR FUCKS SAKE WHAT NOW” silly twat muttered under his breathe. Dripping from the bottom of the carb was green and clear droplets. I knew for a fact all the bolts on the carb were tight, then I noticed the lower carb warmer hose leaking. I don’t know why because the hose was pushed back on to the nipple far enough and the clip over the nipple with it.
I can’t lie it sent me over the edge because the coolant is bright green yet there where also clear droplets mixing / forming with the green. I really don’t fancy taking the carb off again assuming it’s petrol leaking however a quick whiff and there’s no petrol smells.
Ya know when you’re really tired and ready to call it a day but you just can’t give up? I’m at this point. Luckily after a bunch of faffing around and head scratching the coolant leak stopped. It was the carb warmer hose not sealing the whole time.
As to why or even how the bright green putoline coolant decided to turn clear I don’t know. It probably did it just to fuck with me. Who knows? 😂
By this point I’d run out daylight and with what was a full tank of petrol mostly on the floor I thought it’s time I call it quits 😂
With that being said silly twat returned to cave he arose from to return another day with more energy and enthusiasm.
Silly bike things aside I took 3 different calls for new jobs! Overall making today a pretty good productive day
All that’s left to do is actually go take the bike out for a ride and see how things go.
I’m also going to have a day where I ACF50 the bike and give her a deep clean and detail. She deserves it and as mentioned it’s been too long. It’s just hard to keep on top off when she’s always getting dirty!
If things haven’t worked themselves out then the only thing that leaves me to check is HT lead / coil !
Outside of getting to Rev out that just leaves using @HOTSHOT-III tips and advice to sort out the oil pump and gear shaft seal.
Anyway’s good evening chaps. Hope you got a good laugh out of some of the mishaps I was having. Sorry about the “wall of text” I was so busy I completely forgot to take photo’s. Alll
@SpookDog Yes I think it was someone with a TDR125?
@Stevie-Wonder Sounds like you're moving forward with this, those pattern fuel taps are a bit of a mixed bag but I've bought good ones before. Next time you have to disturb the carb warmer hoses, just bypass the carb altogether and run a single hose from the banjo on the head directly to the one on the thermostat housing. You still get the benefit of the cooling system being self-bleeding when refilling, but it makes the carb a lot easier to remove and UK winters aren't really cold enough to worry about carb icing.
