Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Hey just curious have a 01 dt125 r with a broken bleed nipple will a 05 caliper with mounts Bolt straight on? Thanks in advance
Swingarms are the same, wheels are the same but the carriers are different.
So make sure you get the carrier and caliper as one unit and you shouldn't have any issues.
If memory serves me correctly.
@Calum thanks for that info! I have ordered the carrier and caliper 😁 hope it works if not do you think I could just swap carriers?
