hid headlight conversion
hi all, hope this is the correct place to post this but has anybody tried to convert there headlight to hid.now the dark nights are drawing in i have found the headlight to be useless.
do you wire it direct to the battery and if so how does this affect the battery
thanks for any suggestions -
HID are awfull in a reflector that isnt made for it, you get more light, but not where you need it.
If our lights are DC (which i presume) a good LED light might be an option. (I have it on my xt600 and my wr250r) But each reflector is different..
Something light this: http://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html
@admiral323 I looked in to this with my DTR, but the cost was too much and I wasn't sure if the battery was up to it either? So I found this alternative instead;
Basically double the brightness of the standard bulb, with a lot simpler installation done in 5 minutes and as cheap as chips too!!! ;)
@admiral323 you decided to post on here in the end, nice! :wink:
I ran HID kit on my dtre. Was super bright. Agree about the pattern though.
It tends to blind oncoming drivers. The ballast needs to warm up so often it didn't work immediately.
Other than that it was an okay upgrade, but I eventually reverted back when it took a whike to turn on.
thanks for all the replies.i see what you mean about the reflector.think i will go with the bigger bulb just now to see what it will do
@MIGHTYMAN thanks for directing me here its a mine of usefull stuff for my bike
did you get the 100/90w or the 60/55w version as need to get some better bulbs for mine
@britshgigolo Are you asking me or @admiral323???
Ehr, the rectifier burns uo unused current, so the more you need the easier a life it has.
But the stator cant cope with 100W so the light will probably be dimmer than a 65w
well i ordered the 65w one so hope they will be ok nd give more light than the standard bulb
@britshgigolo The OEM bulb is only 45W, I had a 55-60W white bulb in mine before I switched to the 100/90W one. Even the 55W was an improvement over the stock bulb, which was more like a crappy house bulb and not the regular car type ones. But obviously not as good as the 90W. Which I ran with no problems on my DTR, but then maybe some problems would surface over the long term? Only time will tell I guess???
i got the 65w bulb and fitted but not tried it yet in the dark but looks lots better than the standard bulb but time will tell
I spotted these on ebay, might be worth a shot and a decent price if there not to fiddely to fit???
would these not be the same as the ones posted above where the light is scattered and blind on coming vechles because of the reflecor
