Temp gauge trouble shooting
@declan said in Temp gauge trouble shooting:
@calum do the thermistors generals go bad? They seem like gold dust
I be got a scrap head if the thermostat will unscrew with out breaking you can have for it postage it's untested an I m gonna be using a vapour speedo with temp sender so the the thermostat is no use to me -
Never heard of them going wrong personally, DTRE doesn't have a temp gauge so it's never been an issue for me.
They get hot but they keep running.
You can get a temp sender for the vapor that screws in where the original goes. That's what I did so I have a nice reading on my unit.
120x120mm fan fits, i mounted one from a pc as a test.
Makes removal of the sparkplug a slightly bigger hassle
@jens-eskildsen sorry to be the one to tell you this, but for one, you have the fan blowing the radiator the wrong way, rendering it useless as soon as you start to move
secondly, pc fans are useless in vehicle application, they offer literally nowhere near the amount of airflow that moving even at 5mph provides. typically a PC is generating 150w of heat or less, thats 0.15kw, whereas a bike such as this is making hundreds of times more heat.
you need an automotive fan to make an ounce of difference
wow hahahahahahaha :joy: :joy: :joy: :joy: :joy: :joy: :joy: :joy:
@declan it probably the same one for other motors so could pick one up for £5 ish maybe measure the thread and ask sellers ect don't worry about the connection that's easy fix you probably have some old connector around -
Tom, I know, as I said, it was a test to see if it would fit.
Its mounted on the right side tho, and its supposed to suck air, not blow it, so it pulls air through the radiator. -
@jens-eskildsen yeah in my mechanics course we were told that some fans suck air through the radiator fins and others blow it through guess it doesent really matter
Fan is protected a bit by fitting it on the backside
@jens-eskildsen but it's harder to fit and gets in the way more and then you can't see it
youve got the fan blowing towards the front of the bike... i didnt say it was in the wrong place i said its massively underpowered for application and its blowing the wrong way, its fighting the direction of the wind!
as you can see..
And I answered "I know that", and described in detail that it was only a testfitting.
I got it for free, and now have the wiring sorted for a proper fan, and know what dimension will fit.
Lets move along, shall we?
