Head leak
Just changed the head gasket for my 170 kit.
I was out riding when i saw a leak from the head gasket.
I have cleaned the head, and the cylinder, but i still leaks.
Tried using som gasket sealants, but i stil wont stop.
Its not leaking much, but i still have to fill once or twice a week.
I used athena gasket. -
@Haako-Smith the manual says 16 lb/ft which I believe is about 22 nm.
@Haako-Smith someone on the forum posted a link to download the manual for free. Use the search feature it's here somewhere.
I mean, I don't recall doing mine up to the spec and never had issues.
I do give my head and barrel a quick skim mind you.
https://dt125r.co.uk/topic/11/how-to-i-gentle-skim-your-head-barrel
Thanks for all the respons.
I did skim the head, but i will try to tighten the bolts:+1:
