  3. Bottom End
  4. Balance shaft..
Balance shaft..
Scheduled Pinned Locked Moved Bottom End
3 Posts 3 Posters 2.1k Views
  • dt200wrmanD Offline
    dt200wrmanD Offline
    dt200wrman
    Has anyone ran there bike without the balance shaft? I read on a wr200 forum that it mad a big difference to that engine.anyone tried it with the 125?
      Engines back in the day didn't use to have balancer shafts.
      Obviously it's going to have a dramatic effect on bearing life and, since there are no rubber engine mounts, a dramatic increase in vibrations through the handle bars. It becomes quite unbearable after a short amount of time.
      I would say there are better things you could do to increase performance of the engine over removing the balancer shafter, like lightening the flywheel.
      • Hark_PtooieH Offline
        Hark_Ptooie
        Sorry for commenting on a 3 year old thread, but I have worked a little with balance shafts on humongous machinery and wanted to post a little for posterior knowledge.
        A single balance shaft on a single-cylinder doesn't really do much. It mostly just phase-shifts the vibrations so they go in another direction. Back and forth instead of up and down, like.
        Dual balance shafts is another thing. They cooperate in the right direction, and counteract each other in between - and if you put them slightly offset each other vertically they can even mitigate some rotational moment.
        But balance shafts also have another interesting effect - they can reduce the bearing load. There are actually two different optimums - one which gives the least vibrations but a bit higher bearing load, and another that is the opposite.
        So when I see that small engines have a single balance shaft, I usually assume it is to allow it to manage high revs by means of lowering bearing forces rather than reducing unpleasant vibrations.
        There was a bike back in the 90's(?) - some european single-cylinder 2-stroke 250 cc enduro (cross?) - that had a balance shaft and managed to output 70+ hp when all the balance-shaft-less big-brand competitors only gave 55 hp or so. Because it revved to like 12000 when the others quit at 9000 or whatever.
