  4. Kickstart crank in electric start engine
1 Posts 1 Posters 480 Views
  • dt200wrmanD
    dt200wrmanD
    dt200wrman
    Eyup lads, has anyone tried using a standard kickstart only crank in an electric start engine? I know the electric start crank is slightly longer on the stator side to accomodate the starting clutch, my thinking is if i used a spacer behind the stator the same thickness as the diffrence is length between the 2 cranks then it should work, my electric start has been decommisioned anyway, anyone done similar?
