  4. Can I get a dtre engine into a dtr frame
2 Posts 2 Posters 1.3k Views
  • jimmydc98J Offline
    jimmydc98J Offline
    jimmydc98
    With a kickstart conversion is it a strait bolt in with no modifications or are the frames different mounting wise
    DT200WR 1997 - New Project
    DTR 125 2002 - Project
    DT 125 LC 1986 - Old Bike
      Engine will drop straight in correct.
      However it won't be as simple as that as you'll need the correct CDI.
      The rest should be okay other than you won't be able to use the starter motor. There will not be the correct plug for that so that will cause issues.
      You can't swap stator or genny over cause the crank is different.
      So it will be a bit of effort getting it running.
      But it will drop straight in
