  3. DTX
  4. Is the Zeeltronic worth it?
30 Posts 5 Posters 3.1k Views 1 Watching
    I love mine, I have about 5 Zeeltronic ignition systems and just this week bought another one.
    I'd say, bang for buck, the Zeeltronic made the single biggest impact on my DTRE, over exhaust/Porting/carb the ignition system made the biggest jump in performance.
    • Strike78S Strike78
      Hello everyone!
      I need to replace my cdi and was wondering if the zeeltronic is worth the 300€ or is there anywhere i cant get it for cheaper.
      Thanks!
      @Strike78 It certainly is! If you have an early DTR with the 3NC loom/CDI and 3-wire servo, by running a Zeeltronic and a 5-wire servo (more easily available) it's possible to install it without making any changes to your stock wiring loom. You can then keep the 3NC CDI and 3-wire servo and if you sell the bike or just want to return it to stock for any reason, it's just plug and play.
      I'd just get it directly from Zeeltronic, Borut is very helpful and I ended up with quite a papertrail of emails after buying, he appeared genuinely interested in helping me gain a good understanding of ignition and powervalve maps (it's a lot more tunable if you run a 5-wire servo).
      • Strike78S
        Strike78S
        Strike78
        Thank you guys for the help!
        I’m going to get one, especially because there’s a plug-and-play option compatible with my DTX125. That makes the whole process much easier and avoids having to modify the wiring system.
        I’m also running a full Firebox exhaust on the bike, so I was wondering if there’s any specific map/setup that I should get, or if I should just use the one that comes pre-installed. I don’t really know annything about CDI tuning, so any advice would be appreciated.
          So just go with the stock settings. You can't go too far wrong.
          The easiest way go get started with learning is by having a play with the powervalve timings. You won't run the risk of detination and damaging your engine, so it's a safe place to start
          • Strike78S
            Strike78S
            Strike78
            I ordered one with the connectors already installed👌
            Everything went smoothly and Borut was very helpful throughout the whole process.
            Thanks for the help guys!
              Aww nice! I've just received another Zeel for my RD yesterday. I've got to wire the plugs myself mind you as it's going into a Cagiva Mito.
              • Strike78S
                Strike78S
                Strike78
                I have another question
                Ever since my bike came back from the mechanic a few years ago, it has had very poor low-end power and it never felt the same again. His excuse was that the bigger piston is heavier, but honestly I’m not convinced.
                My DTX is noticeably slower than my friends’ DTRs/DTRE, especially in low RPMs. To be honest, I never went back to that mechanic after that. I already adjusted the YPVS before, but the problem still persisted. I also cleaned the carburetor and installed a new spark plug.
                Right now I’m waiting for the new CDI to arrive so I can properly tune the power valve again and see if that changes anything.
                Has anyone experienced something similar? Could the bad CDI cause such a big loss in low-end power?
                Current setup:
                Firebox expansion chamber
                Firebox silencer (I think)
                Original carburetor
                18T front sprocket
                51T rear sprocket
                  This is most likely the squish.
                  If someone built that top end for you, they probably used too thick a base gasket reducing the compression ratio. The cylinder head could sit be marginally higher than what it was before, meaning the squish is off.
                  I am not saying this definitely the case, but would explain why you'd lose bottom end. I am not sure about the heavier piston, sounds like a cop out, but if a different dome was used, different profile, then same answer. The squish is affected.
                  A vast majority of power on a two stroke is made in the head, so it could be that the squish band isn't correct. This is a very simple and easy thing to fix and measure. All that is needed is a set of vernier calipers and some 1.2mm thick solder wire, with a dab of grease to stop it falling into the bottom end.
                  Could be this, especially as you say, it was fine before the top end rebuild, noticeable after.
                  I once went from the stock 3MB00 cylinder, to the TZR R Belgarda 3MB00P which has a raised exhaust port by 1mm and as a result, greater over-rev (ideal for the TZR) loss of bottom end (less ideal for the DTR).
                  I went from lifting that front end up with ease (no small feat on my heavier setup) to having to work for it.
                  Now I run a ported Athena 170cc kit and I love it for the low-rev grunt. I have my RS125 which is lightening fast so I enjoy both aspects now 🙂
                  I am by no means an expert and please someone else chime in and correct me, but based on what you've just articulated, this could explain it.
                  • Strike78S
                    Strike78S
                    Strike78
                    Thanks for the explanation, that really helps.
                    Would fitting a new gasket kit (especially base and head gaskets) potentially restore the correct squish/compression? or should I consider getting a new top end altogether?
                    I just want to make sure we’re looking in the right direction before replacing parts and not waste money on it.
                    (I realy dont know anything on the mechanical side).
                    Thanks once again!
                      Well, you need to figure out whether this is indeed the problem. Obviously I can't be certain having never seen the bike, you'd need to take some measurements.
                      You don't need to get a new top end, correcting the squish is standard practice on two strokes.
                      • R
                        R
                        Rallyfinnen
                        You can take a piece of soldering tin and bend it and stick it through the plug hole to get a rough measurement of the squish. If the solder is not pinched you can 'double twist' it to get a reading. This should give you an idea if it's the cause. A good value should be 1mm or slightly less IMO. You can find different thickness base gaskets in some places, like here: https://www.motorsportgoetz.com/Cylinder-Base-Gasket-03mm-Yamaha-DT-TDR-TZR-125
                        • Strike78S
                          Strike78S
                          Strike78
                          Sooo... a lot has happened, and it turns out things are worse than they first looked.
                          My Zeel finally arrived and I've already installed it. While working on the bike, I found that the cylinder head is warped and it's leaking coolant into the cylinder, so I've taken it to be skimmed.
                          I also found that the air screw on the carb is completely stripped and there's no way I get it out
                            Oh that's pretty standard on those Mikunis sadly. Very common.
                            Jeez how bad is the head to have warped that much? Depending on how much they skim it by you may need go offest with a thicker base gaaket.
                            • Strike78S
                              Strike78S
                              Strike78
                              Yeah, fortunately it wasn't much warped.
                              I also took the carb to a guy who might be able to remove the stripped air screw. I'm waiting to hear back from him before deciding whether I'll need to buy a new carb or if a carb rebuild kit will be enough.
                              • Strike78S
                                Strike78S
                                Strike78
                                Sooo…bad news me and my friend put the head back together and it stills pour collant through the tube in the radiator…
                                Im lost here any tips? Im checking the head if they skim it right…
                                  Can I confirm, you're talking about the overflow tube right. This is routed to the overflow bottle. You have to allow for water expansion/contraction into and out of the expansion bottle. Don't just route this to the floor.
                                  Secondly, a problem I hear is that the radiator cap looses tension over time. It should be rated to 1.3 bar but they weaken as they age. The result is it's unable to maintain spring pressure and erroneously overflows coolant.
                                  So be sure to check both things are in agreement.
                                  • Strike78S
                                    Strike78S
                                    Strike78
                                    wrote on last edited by Strike78
                                    I'm talking about the small tube next to the radiator cap. Where is it supposed to be connected? Mine just routes down to the ground and I'm almost certain it's always been like that.
                                    The radiator is brand new (a high-capacity aftermarket one) and I got it about two months ago, so I doubt the cap has already lost its spring tension.
                                    The strange thing is that it starts overflowing not even a minute of the engine running.
                                      The tube perpendicular to the filler neck goes to the coolant overflow bottle.
                                      As the coolant heats up, it expands, it needs somewhere to expand in to, this is the coolant overflow bottle. As it cools, it contracts and pulls a vacuum and draws the coolant back into the coolant system.
                                      The radiator cap is spring loaded (I believe it's 1.3 bar) and that pressure is needed for the coolant to vent into the overflow bottle. You shouldn't be ditching this to the floor, it goes to the coolant overflow bottle.
                                      As seen in the picture above.
                                      • Strike78S
                                        Strike78S
                                        Strike78
                                        Quick update: everything is back together exactly as it should be, but unfortunately the problem is still there.
                                        At this point I'm leaning towards buying a new head and seeing if that finally solves it.
                                          I skim both the head and barrel.
                                          https://dt125r.co.uk/topic/11/how-to-i-gentle-skim-your-head-barrel
