  3. Ypvs barrel removal
Ypvs barrel removal
4 Posts 4 Posters 1.3k Views
  • olliedtx12sO Offline
    olliedtx12s
    Hi is there anyone out there who can tell me how to remove the ypvs barrel so I can clean it up, removed the cable housing off the left side along with the orange seal behind it, removed the small round cover from the right side behind expansion chamber but that's as far as I've got. Any help would be much appreciated?
    Irongamer727I Sgt Robuck 5S 2 Replies Last reply
    • olliedtx12sO olliedtx12s
      Irongamer727I Offline
      @olliedtx12s there is a screw you have to remove on the right side. Then you should be able to pull them apart
        Take care not to lose the locating dowels.
          Sgt Robuck 5S Offline
          Sgt Robuck 5
          @olliedtx12s If you need to locate any specific parts click on this and I suggest getting a haynes manual Found on here Amazon
