  4. 520 pitch sprockets from YZ 125 - which fit?
3 Posts 2 Posters 2.0k Views
  • M Offline
    M Offline
    MDN91
    Hi!
    I'm about to replace the chain kit on my 1995 DT 125R, and want to do the 520 pitch upgrade - I know people are fitting sprockets from an earlier YZ 125, but from which years can I fit?
      I knew it was 2004 front sprockets 520 fit. But that era of YZ runs 428.
      If you go to B&CExpress they sell the 520 conversion kit. That's what I bought
      M 1 Reply Last reply
        M Offline
        M Offline
        MDN91
        @Calum I wanted some options in ratios, so that's why I didn't just order a complete kit - did some research and learned that following JT sprockets fit:
        Front - JTF 564 (for an example, JTF 564.13 is a 13 tooth 520 sprocket)
        Rear - JTR 853 (for an example, JTR 853.50 is a 50 tooth 520 sprocket)
        Thought this might be helpful.
