  4. Unburnt oil from ypvs housing
4 Posts 2 Posters 748 Views
  • W
    W
    waale2004
    I have a dtr 03 model fitted with Athena 170kit, Athena exhaust and 32mm flat side. And I keeps coming unburnt oil out of the power valve on the left side where the cables go in. I have a 122 jet now and before that i had the original carb with 300 jet at it just keeps coming oil. I have even tried changing all the o rings and seals on the powervalve but after a few rides I just keeps coming. I am also riding with 2% oil mix
    • W waale2004
      @waale2004
      Again...
      @waale2004
      You changed the seal as well as the o~rings. I don’t know if the Athena kit uses special or standard parts? 2 o~rings & 1 bush seal. These are the only parts that can be a problem...
      Do you premix 50:1?...
      W 1 Reply Last reply
        @waale2004
        Again...
        @waale2004
        W
        W
        waale2004
        @spookdog
        Yes i mix 50:1 and i have tried changing The o seals with new ones and the red bushing all from Athena. It work for a little while after I changed it with new ones but after a while it seems like it builds up pressure and then blows everything out.
        • W waale2004
          @spookdog
          @waale2004
          Check your plug colour. I’m guessing you are running rich with a wet black plug. Cause at 50:1 all your oil is being burnt/used. It can only be excess fuel...
