  4. Dellorto phbh 28 connection
2 Posts 2 Posters 537 Views
  • A
    A
    alisov23
    Hi guys! Sorry for the off-topic, since this is not exactly about Yamaha DT motorcycle, but about Sachs ZZ 125, which shares the same engine.
    Couple of months ago I have removed the carb for cleaning, and now while attempted to re-install it on the bike, I have encountered a few problems 🙂 too many fuel line, and not too many ways to put them in. Could you please help me out ?
    I have two lines for coolant, which is pretty self-explainatory and the main big line to connect the carb to the fuel tank. but unfortunately I have no idea what to do with the others.
    Could you please help me out with this ?
    Please see the photos of the card below :
    https://ibb.co/zZ1xLQT
    https://ibb.co/ryHQjGt
      They are fuel overflow hoses. Attach a hose like shown on the other side and feed it underneath the bike away from any hot areas.
      They're designed to flow gas away from the bike and hot areas should the bike fall over and the tap not be shut off.
