DT200 Super Moto Wheel
Hi, i hope i'm in the right place. I'm looking into converting my DT200 1991 into a SM. I would like to know which wheel would fit bolt on? or What Rim / Spoke i need to order to convert mine. Also which front fork would work? Thanks
Hi, i hope i'm in the right place. I'm looking into converting my DT200 1991 into a SM. I would like to know which wheel would fit bolt on? or What Rim / Spoke i need to order to convert mine. Also which front fork would work? Thanks @pelplouffe I 'm sure someone will correct me if I am wrong? But I believe that the DT125 and 200 share the same frame? I know that the front forks and swingarm are different, as well as the rear shock too. You could do a USD fork conversion on the front and a custom brake caliper mount will enable you to run a larger front disc brake set-up. But for bolt-on straight swap parts this thread will help get you started; http://dt125r.co.uk/topic/207/how-to-supermoto-a-dt-using-donor-parts-from-other-yammy-s
