  4. Powervalve question
Powervalve question
5 Posts 2 Posters 1.3k Views 1 Watching
  • RickyR Offline
    RickyR Offline
    Ricky
    wrote on last edited by Ricky
    Hi guys i have the dtx I've stripped the top end and just wondering if I should be able to turn the Powervalve 360 degrees or not and when I set it up so that it's flush with the exhaust port the hole on the pully doesn't line up with the hole on the casing it's slightly off to the right
    DT 125X
      Have you installed the powervalve upside down?
      With the plastic cap off the near side of the bike, you should be able to rotate the valve 360 degrees. It should move quite freely.
      If the barrel has been rebored then you will need to modify the valve to stop it hitting the piston.
      RickyR 1 Reply Last reply
        RickyR Offline
        RickyR Offline
        Ricky
        @Calum thanks don't think it's upside-down or been rebored still on standard size piston but it's definitely hitting something as it won't turn all the way round
        DT 125X
          Without looking at mine I really couldn't say if it should spin all the way around or not.
            RickyR Offline
            RickyR Offline
            Ricky
            @Calum I'll upload some pics of it soon see what you think
            DT 125X
