YZ Swingarm on DT?
I know many of you have done this in the past, and I think this looks absolutely the tits when done properly.
I've been wanted a hassle free Aluminum swingarm for a while not, but being able to find one has been tricky.
So it's going to have to be another custom jobby for this one.
I've purchased myself a YZF 450 Swingarm (YZ125)
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/bw0AAOSwstxU9OJG/$_57.JPG
Should be an interesting project.
My main reason for not doing it previously has been due to the fact that I needed to modify the rear brake caliper holder for the wheels, and I didn't want to work on it again since it was a lot of work.
I know there won't be any gain for doing this. Only other than a kick ass swingarm that I think will really polish off my build.
Not much has happened with my DT, few things powdercoated, but most of my effort has been on the Starlet. But I'm itching again to get back building the DT so I will make more effort in this last half of the year to really make some headway. Finish the engine build next month, and get the frame into the coaters.
On the plus side I've found someone to do my wheels, the colour is going to be EPIC!
Anyway, if people want to post their conversions and thoughts I'd be grateful!
Literally, looking at that photo, Ally, a fair few hours with cutting paste and sissel mop...How BADASS will that look polished up!
I'm guessing that will look better polished than it would Black...
Ideas ideas!
Good luck mate it is a pain to do the linkages are the worst bit as for caliper ect it would be easier to get a yz hub laced to your rim then you can run the 520 pitch chain aswell
Also what year swingarm are you using as I have a caliper and carrier here that I bought in error for mine as certain years use different carriers
Also the yz rear disc bolts straight onto the dtr hub if you decide to go that way dtr rear disc is 220mm and yz is 245mm
YZ hub on my wheels...are you kidding mate, it's an all ally wheel lmao!
Don't worry, I ain't a stranger to a little machining. After mounting Aprilia RS125 wheels, brakes and WR250 USD forks, there isn't alot I haven't done.
The amount of work done to my rear brake caliper carrier I done, I'd be made to start again
I just reckon this final little tweak will just finish the bike off nicely.
I run a 520 pitch chain anyway. You can get 520 pitch for the DT easily.
And I run RS wheels which are naturally 520 pitch, but personally, why 520 pitch? That's more weight for the final drive, best to keep that light. My brothers YZ125 only uses 428 pitch, and a lot of GP bikes only run 428. Better power
Forgot you was running the rs wheels lol what size rear disc does the rs use ?
I don't know off the top of my head. The Front one is clearly bigger, but the rear one could be about the same size.
If it runs the 245mm disc all you would have to do is make a spacer for the wheel which your pretty capable of doing, I was thinking about spoked dt wheels when I said about the hub lacing haha
And what year is your brothers yz as I can't for the life of me find a 428 pitch rear sproket my rs was 520 pitch but put it to 415 pitch but was forever replacing it which was fine if I was racing but for road use the 520 pitch chain is stronger
His is a weird one. I believe it's 2002-2003. Yeah I was kidding lol.
His YZ is this really weird model where Yamaha decided to use a 5 speed box etc.
Yeah, the spacers got trashed when the sprocket bearing collapsed. So that has to be made up again.
Shouldn't be too much more work to get it to fit to be fair. I only just got the Swingarm and won't be looking into it for a few months yet anyway. Lol.Thanks for the input
Well if you get stuck and need any measurements off the yz caliper carrier give me a shout as I'm sure the carrier I have fits your swingarm
Thanks, I will be alright. The Swingarm is off the same.model YZ my brother has. So will take measurements from that.
I think, I was very much inspired by your project. I have seen many dt's with YZ swingarms. But yours just inspired me to do it to mine. So thanks for that
Ah that's ideal then the calipers and carriers are the same from 99-04 I messed up and bought an 06 swingarm and an 02 caliper by mistake but near enough have everything to finish it now, just need to cut off my lower linkage mounts and mount my new ones then the rear is basically finished
7/16
