  4. Vibration problem
Vibration problem
6 Posts 2 Posters 962 Views
  • B Offline
    B Offline
    Bananper
    Hello guys so i figured out that i'd just open up a new topic instead of continuing on my old topic.
    So the problem is that my DT is making these annoying vibrations when i ride around, what i've figured out is that it must have something to do with the clutch, because when i pull in the clutch i can hear a wheel or something like that slowing down and when it stops slowing down and i rev it it doesn't vibrate. Also i've noticed when it's idling it makes a rattly noice when the clutch is not pulled in.
    What could be the cause? I changed the clutchplates after i had this problem so that can't be the issue here, the only thing i noticed that looked wrong was this little freeplay on the axle that holds the clutch basket: https://www.youtube.com/watch?v=3ZEvNP-LKpU
    Thanks
    B 1 Reply Last reply
    • B Bananper
      Thanks
      B Offline
      B Offline
      Bananper
      also, on idle i can hear a little tapping noice, i don't know if this has anything to do with it
        That's mental. Definitely shouldn't be doing tht.
        If I had to guess, I'd say worn dog ears.
        That's the primary gearbox shaft, which engages with the output shaft.
        I can't say I've ever noticed play like that, but at a guess I'd say no way!
        Check the output shaft for similar play. If the output shaft exibits no play then I'd say the primary shaft dog ears are excessively worn.
        If I had to guess!"!!
        B 2 Replies Last reply
          B Offline
          B Offline
          Bananper
          @Calum pretty much no free play on the output shaft (thats where the sprockets supposed to be right?)
            B Offline
            B Offline
            Bananper
            @Calum where are the dog ears located, sorry i'm not really good at this 😅.
            • B Bananper
              @Bananper The dog ears are in the gearbox, they are what shift the gear cogs into place from the selector drum.
              I can't see why there would play. The primary shaft is fastened against the case and the bewring.
