  4. photo of battery wires needed
6 Posts 2 Posters 749 Views
  • D Offline
    D Offline
    dan28
    i ve fitted a dtr engine into a chopper an i ve had to run the wiring through the frame
    i have two wires (black an red ) labeled battery but they have no terminals or inline fuse
    do the battery wires unplug from the main loom could someone post a photo so i can see where i ve gone wrong
      The negative lead goes from the battery to the frame. Or rather it does on the RE. The positive lead goes onto the fuse holder. Again, or rather it does on the RE.
      There are other negative terminal leads which merely go from the coil to the frame
      • D Offline
        D Offline
        dan28
        i dont think my loom came with either of these what ampage is the inline fuse sounds like i will have to buy a fuse hold an make an earth wire
        • D dan28
          @dan28 20 Amps, again RE has the starter motor and relay. Might be 15 on the R.
            D Offline
            D Offline
            dan28
            @Calum said in photo of battery wires needed:
            thanks calum maybe some one with a dtr can confirm this ?
            • D Offline
              D Offline
              dan28
              can some one with a dtr confirm the fuse is 15 amp?
              a photo would be be helpful too
