  4. Really bad vibrations
18 Posts 4 Posters 2.0k Views
    None of the engine mounts are loose are they?
    Haako SmithH 1 Reply Last reply
    • Haako SmithH Offline
      Haako Smith
      Hmm yea, maybe it could be the bearings, although I changed one of them last winter, I know I should have changed both but I only have one 🙂 Yea, all of the nuts were tight and no loose nuts
        Haako Smith
        No, all are tight and good!
        • Haako SmithH Haako Smith
          @Haako-Smith
          I just re read your first post. It won’t rev up...
          One thing you can try is to turn the engine over by hand. Turn the magneto rotor over, back and forwards, see if it feels ‘crunchy’ at all. Anything but smooth...
          P.S. has the posting format changed? I could only find the ‘button’ I normally use in the first post. I’ve never seen the @whoever reply thing before...
            @Haako-Smith
            Haako Smith
            Hey.
            The I tried to rotate, and it feels like normal. Nothing crunchy or anything. I also tried to swap the clutch basket out with another one I had laying around, which I knew worked when I took It off. I started it up and with no luck, same vibration 😞
            Yea I also saw the @thing haven’t seen it before.
              Hey.
              @Haako-Smith
              dude, if the engine is tight in the frame and you’ve already been clutch deep. You’re going to have to go deeper. It can only be something that’s spinning and out of whack. Which is clutch side (input) gear shaft, balance shaft and crank. There is nothing else. My concern is that if the bearing race has failed, where is the metal? It could only go out round the inner crank case...
              Only other thing I can think of is the rotor woodruff key. Remove the rotor and check the keyway on the shaft. I’ve had these go bad and ruin the key slot/hole, no matter how much I tightened it it wobbled loose. I had to braze a woodruff key into the crank in the end...
                @Haako-Smith
                Haako Smith
                Hmm yea, I took the woodruff key out, and it looked good. Maybe I just have to start taking it apart🤔
                  You can always pop the oil seals before you split the cases. Whatever, you’re gonna have to take off the top end to get a look at the crank. I think surgery is the only option 😐
                    When i was riding today, all of a sudden my bike started vibrating like mad. And it seems like it won’t Rev up. I checked the balancing shaft and flywheel, which all seems fine. However the clutch basket has quite a bit of play between the actual cog and the basket. Could this cause mad vibration? Or what else could?
                    jamesJ Offline
                    jamesJ Offline
                    james
                    @Haako-Smith have a look at the bottom end bearings very easy to mis hap for good wen bad pal just had the same thing 1 of the bottom bearings were shot hope this helps pal
                      Haako Smith
                      • jamesJ james
                        Haako Smith
                        @james
                        Thanks for the tips!
                        I have a spare engine that I will swap it with in the meantime.
                        Thanks to everyone who have helped!
