  4. Temperature sensor DT 125 R
11 Posts 4 Posters 3.2k Views
  • Hybrid_Theory01H
    Hybrid_Theory01H
    Hybrid_Theory01
    The temperature sensor threaded in the head only has 1 wire, how does it work? How can it give precise feedback of the temperature with just 1 wire? It changes the resistance according to the temperature?
      @Hybrid_Theory01
      Yep! The engine is the earth and the temp gauge reads the differing resistance along the single wire...
      Do you have a temp gauge or a red warning light?...
        @Hybrid_Theory01
        Hybrid_Theory01H
        Hybrid_Theory01H
        Hybrid_Theory01
        @SpookDog i don’t haven either, previous owner removed original warning light speed and tachometer and installed a aliexpress one, im planning to make my own display
          @Hybrid_Theory01 Sounds like a cool project, stock DTR clocks are off the scale expensive now and I've never liked the looks of the Aliexpress ones.
          Maybe take a look at these, the GPX TSE250R uses a DT230 Lanza engine built under licence and runs digital clocks. You might need the wheel sensor as well for the speedo but these are around half the price of Trail Tech etc.
          https://www.gpxmotouk.com/store/p97/Speedo___ignition.html
            Hybrid_Theory01H
            Hybrid_Theory01H
            Hybrid_Theory01
            @HOTSHOT-III I Will probably use a arduino to measure RPM with a induction sensor in the spark plug wire and engine temperature and a bicycle speedo for speed and put it all in a little box to make it look decent and to have some protection
              @Hybrid_Theory01 That sounds good, post up a how-to on here when you've done it! I ran a bicycle computer on a grey import 400 (with kmh speedo) back in the 90s, a lot of them are backlit now and have a lot more features. And programming in wheel circumference makes them 100% accurate even when experimenting with tyre choice 👍
              CalumC Hybrid_Theory01H 2 Replies Last reply
                @HOTSHOT-III I was thinking, you can get GPS modules for Arduinos pretty cheap. And GPS speed is really accurate. Only works if you're moving though 🤣
                  Hybrid_Theory01H
                  Hybrid_Theory01H
                  Hybrid_Theory01
                  @Calum heard about these, it might actually be a great idea
                    Hybrid_Theory01H
                    Hybrid_Theory01H
                    Hybrid_Theory01
                    @HOTSHOT-III I will be basing myself on this project, but probably without shift lights: http://hackalizer.com/arduino-rpm-meter-and-shift-light/
                      Hybrid_Theory01H
                      Hybrid_Theory01H
                      Hybrid_Theory01
                      @Hybrid_Theory01 said in Temperature sensor DT 125 R:
                      https://kokoraskostas.blogspot.com/2013/12/arduino-inductive-spark-plug-sensor.html
                      https://www.youtube.com/watch?v=INUFziONEjY
                      • Hybrid_Theory01H
                        Hybrid_Theory01H
                        Hybrid_Theory01
                        I started working on it 🙂
